- 6 Sep 2016
How much did you spent getting all the gear and gas? I can’t see this breaking even less you have lots of scrap with a constant supply of it.
its not that bad if you know scrap yard owners..basically you buy whats called " irony alley " normally by the ton. the thing is he seems like a hobbiest. so for money its pretty much pointless unless you want to make things. putin has announced hes going to be giving the usa 2 million tons of alley soon so prices will at least adjustHow much did you spent getting all the gear and gas? I can’t see this breaking even less you have lots of scrap with a constant supply of it.
you ain't rescuing yourself after the whole 'smelting' malarkey
iron alley you say......its not that bad if you know scrap yard owners..basically you buy whats called " irony alley " normally by the ton. the thing is he seems like a hobbiest. so for money its pretty much pointless unless you want to make things. putin has announced hes going to be giving the usa 2 million tons of alley soon so prices will at least adjust![]()
haha its what you call it. iron / aluminum . basically things with part aluminum part steel iron. like gear boxes. i used to buy 1 ton of it then strip it . you can also just stick it in the smelter like hes on about make ingots which are a good price.iron alley you say......
Is it really?haha its what you call it.
*Cough* Post #12 *Cough* - there is no redemption here young man
Is it really?
I have a garden full of copper and aluminium.
Old heating boiler.. copper pipes.. electric 3 phase motors.. etc etc
So bought a metal melting furnace to melt it all down and mold in ingots..
Easier to weight up and sell too..
as said the general rule on motors is you get a third of the total weight of the motor in copper. oldskool way would be break em open whichever way you do it upto you. then they would burn them on a fire.this makes the copper literally fall out or easy to pull out. do that now same as burning copper cable. you can get 9 months in prison.Copper pipes of 15mm, 22mm and 28mm can still be useful for plumbing repairs. If they are in good condition you could sell them to someone who could use them. You'll get more than the scrap price for them.
You could disassemble the electric motors, remove the copper wiring and then sell it and the steel/aluminium motor bodies separately to a scrapyard. Not sure if it's economically worth doing it though.
i know what irony aluminium is - i've just never heard of irony alley.What Is Irony Aluminium?
This grade of scrap aluminium is regularly used for vehicle parts including gearboxes and engines.
In general, reputable scrap yards will categorise your waste as irony aluminium if 70% of its weight consists of aluminium metal. The remaining 30% is typically steel.
You can make a surprising amount from irony aluminium in the UK!
Submit an enquiry to Scrap Local to see how much you could be offered to scrap your aluminium waste.
just what we call it.i know what irony aluminium is - i've just never heard of irony alley.
