i used the MX-6 on my 3080 would not recommendWould MX-6 paste be ok? as it seems reasonably priced and good stock.
you'd need a thicker/more viscous thermal paste
something like the gelid gc extreme, or thermalright tfx
I ran out of MX-4 in 2019 lol, only have my tube of MX-6 left so couldn't do a head-to-head on the 3080MX-4 was cheap, and very effective. Seems to be the best all round TP you can buy that isn't junk.
Or syy 157 never heard of ptm7950 don't think it was known 3 years agoi used the MX-6 on my 3080 would not recommend
i've never used that paste before, so just recommending products that i know :xOr syy 157 never heard of ptm7950 don't think it was known 3 years ago
yes, but very very fiddlyptm7950 you say, very interesting. I noticed thats what Sapphire are using in there 9070/XT models as well. So its just like a thermal pad that you cut to size and stick on?
Any major objections to the above?
TLDR - new front pads = -14c improvement, new front and back = -16c improvement, so doing the back not hugely worth it, however I expect to see a ~-20c improvement in my 3080 due to age.
ptm 7950 is best for gpu, no pump outptm7950 you say, very interesting. I noticed thats what Sapphire are using in there 9070/XT models as well. So its just like a thermal pad that you cut to size and stick on?
I imagine its incredibly thin and a pain to work with though. Challenge potentially accepted.
extreme should work cause they compress more, ultimates are firmerAll round gelid ultimate 1.5mm worked for me after 2mm extreme didn't
you need to open it up again and see what the paste looks like, see if its making contact and full coverageSo I took the old girl apart and it didnt really go very well.
1st attempt was with 2mm pads all round (as in the front pcb) plus a repaste of course.
It then was much worse than before, thermal throttling even at 35% power limit, very disheartened.
2nd attempt, I just repasted as I figured maybe I just didnt do a very good job, but the result was the same, but I noticed very little thermal paste on the heatsink, so....
3rd attempt I changed the pads on the memory to 1.5mm (as advised in the link I gave yesterday, my card is date dated end of 2021 so likely does need 1.5mm not 2mm) and once again repasted, now it runs slightly better than before but will still thermal throttle over 75% power limit.
I've given up for now, but not sure what i'm doing wrong, all I can try really is 1.5m pads all round, Im tightening the leaf spring as far as it will go, without going crazy so I don't think it's that. It even idles 20c lower now and fan stop will even kick it, but under load it quickly overheats again. shrug.
and this is how it was when I first opened her up, no suprise it was over heating haha.
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
imgur.com
And thats how its running now, but will thermal throttle in game pretty quickly.
Didn't in my case , I used extreme didn't work I tried 1.5mm and 2mm , ultimate 1.5mm worked and card still running now 3 years temps haven't changedextreme should work cause they compress more, ultimates are firmer
