Good.
That's how it should , clearly the majority of post points to intel just look comments consensous.
You should look into intel quicksync which you briefly dismissed at the start , especially on newer chips it's way better than some cheaper GPUs for this stuff.
I personally want the best pc for your money/needs which is intel in this scenario imo but that doesn't mean an AMD won't do the job , it will but probably slower compared to intel until you chuck in a decent GPU.
Revisiting your original parts list you don't need a 750w PSU a 500w would be more than enough while still allowing to add a better GPU.
Phanteks case is atx while motherboard is matx so you could get a smaller case if you stick with matx motherboard even if you switch to intel.
Which of the Intel CPUs in the earlier posted image would you suggest going for - 12600KF was touched on, reckon it'd be affordable enough. How does quick sync work on the fact that one doesn't have integrated graphics - would I need a GPU alongside it instead?
Also, any and all advice on a good newbie-friendly (installation-wise) cooler would be much appreciated (I can post a list of what there is in NZ if needed). I use the tall/heavier ones but I don't trust my stepdad to have a careful/balancing touch.
Definitely agree I don't need a 750W PSU, but I wanted a Gold modular with enough connectors for any potential GPU. Somehow the 750W was the cheapest option there, outside of other manufacturers I'd never heard of (I did a bit of research and apparently they were C or below on the PSU ratings, which put me off). Again, seems like just a whole lotta NZ parts struggles. PSU options below (criteria: 2x 8-pin, modular, gold):
Dropping 8-pin just allows for the Silverstone SX500-G and the Fractal Design Ion SFX 500G - the only 500W 80+ Gold PSUs in NZ, it seems.
And yep, case size is honestly my biggest question mark of all. I'm very bad at estimating how much space I need in all directions for that stuff, especially if I do potentially end up needing a GPU down the line. Welcoming even more input there if possible, potential ideas, etc. I've not built a small PC for a long time. Probably best to settle on the parts first, though, I s'pose.
Would buying from Australia be an option?
Still high prices i know
But at least in Australia I had no problem
Finding pc stores
Not as ideal as buying in NZ
But if anything fails you're not having to ship it too far
Done an awful lot of telephone pc help
In the past for friends and family
Frustrating as #### at least nowadays you can video call
And presumably they're up to installing TeamViewer
Would definitely suggest once it's done
That you either walk them through or use TeamViewer
To make a baseline image backup
For any future disaster recovery
Probably add a 64gb flash drive to your shopping for that
Yeah, the plan is to guide them through it over a video call for some of the PC build, and then once TeamViewer is installed I'll just remote in and do all the software side of things. They have an external drive, I believe, which will help avoid the USB problem - but I'll probably have them use a USB drive at the very least for potential BIOS upgrades that might be required.
Could buy from Aus but again, would prefer buying NZ so Mum can get better local support. The parts don't have to be perfect - they just need to be reliable parts, and they need to do the job.
