- 25 Sep 2011
- South Staffordshire
ASRock B650M Pro RS
AMD Ryzen 7 7800X3D
32 GB DDR5-6000
Corsair RM850x (2018) 850W PSU (manual)
I have just bought an RX 9070 XT, which will replace my RTX 3080.
I used the same PSU cable that I used with the RTX 3080 (page 6 of the manual, labelled 'PCIe 8 pin (6+2) cable').
I used Safe Mode and DDU to remove the NVIDIA drivers, and also used Safe Mode to install the latest Adrenalin v25.3.1 drivers.
I have a primary LG C4 (HDMI only) (144 Hz) and a secondary LG C2 (HDMI only) (120 Hz).
The RTX 3080 only had 1x HDMI port, so I used an active DP-HDMI adapter with the LC C2 and it all worked fine (144 Hz on the LG C4 and 120 Hz on the LG C2).
My new RX 9070 XT has 2x HDMI ports, so I was hoping to skip needing the DP-HDMI adapter.
When I connect the LG C4 on its own, it detects 144 Hz in Windows and I can play games with no problems - they run as exactly as they should (i.e. far quicker than the RTX 3080 did).
As soon as I connect the LC C2 (via HDMI), AMD's drivers say there are driver hangs (or something to that effect) and within a few seconds, the system locks up.
If I try to connect the LC C2 via DP (via that adapter), Windows detects it and I can use it a second display - but Windows is now detecting it only as having a max of 60 Hz (instead of 120 Hz that the display is capable of). When I try to force 120 Hz, I just get a black screen on the LG C2.
I am starting to already regret leaving NVIDIA.
Can anyone please assist?
AMD Ryzen 7 7800X3D
32 GB DDR5-6000
