27,640 is your combined score (cpu+gpu) your graphics (gpu only) score is 29,618Really interesting, thank you. I'm also running a Steel Legend and base for me is 27,640 (http://www.3dmark.com/spy/54026775) - so going to start tinkering from here.
+10% power then undervolting in steps of 25/20mv until not stableWhat Adrenalin settings if any are people using with these cards? Should i just stick it on performance and forget about it?
Yeah, I get that - it was just in response to @Bumhug sharing his combined scores!27,640 is your combined score (cpu+gpu) your graphics (gpu only) score is 29,618
https://imgur.com/a/LUjIIYJ
Officially joining the club, or do I ebay it? ;p
Thanks yeah, not on mine either.Saw this in the rumour thread: https://www.pcgamer.com/hardware/gr...rease-in-cooling-capacity-or-product-failure/
Check your cards, I don't remember seeing this on mine but I don't remember removing anything. I'll double check later.
I had it on mine and was a pain to remove. No ides what it’s where it is either but they did have a sticker telling me it was there at least.Saw this in the rumour thread: https://www.pcgamer.com/hardware/gr...rease-in-cooling-capacity-or-product-failure/
i was having issues, and i just reformatted my pc to get rid of any nvidia trace, works fine nowstarting to think it wasnt a wise idea going back to AMD, constant sound drop outs in game, games are stutterfest, constant driver crashes at stock, no oc or uv, never had none of this with the clowns in green, spend half my gaming time on google looking for solutions, hmm
yep even though used ddu seems like i still getting issues, trying to avoid a full reset again, must be on my 3rd this yri was having issues, and i just reformatted my pc to get rid of any nvidia trace, works fine now
i tried ddu didnt work, the same game wouldnt run through steam or xbox app.. so new it was driver related.. and steam and xbox can resync the gamne files anyway so doesnt take that longyep even though used ddu seems like i still getting issues, trying to avoid a full reset again, must be on my 3rd this yr![]()
yeah sometimes is cached shaders in games such a painyep even though used ddu seems like i still getting issues, trying to avoid a full reset again, must be on my 3rd this yr![]()
Free power id say. These cards do appear to boost above the manufacturer listed speeds. They always list the minimum they'll achieve but it's still more power.Thanks yeah, not on mine either.
A really cool card actually (9070 Pulse).
Speaking of which, I seem to be getting a GPU boost clock of 2750Mhz instead of just over 2500.
Both GPU-Z and hwinfo report the same.
E: Since then GPU-Z has reported near 2900 and hwinfo just over 3000. Not sure what's going on, whether that's actually happening or if it's just a reporting issue.
Memory stats and total power draw seem spot on so, hm, maybe it's just free powah![]()
Do you have a spare disk or USB drive. Trying installing windows onto that. Do you have any errors in event viewer.yep even though used ddu seems like i still getting issues, trying to avoid a full reset again, must be on my 3rd this yr![]()
