- 6 Sep 2016
Windows 11 debloated version is fine
I don't understand why there's about 3 or 4 different 'sound' settings. ? I can never remember which settings i need to change a certain thing. The network is the same.I think the look and functionality of Settings is much better than 10, the general look of the desktop and rounded corners on windows is a bit better. There's probably a couple of other things but I can't remember now I'm not sitting at the PC.![]()
yeah is it 'properties' or 'settings' ? 'Control Panel' or 'advanced' or in sounds, just 'Sounds' Like that tells me what i need to know. I'm already on 'Sounds, i right clicked it, but then you give me a menu named 'sounds' Jeseus wept. You can get literally about 10 clicks deep before you find the settings. Wait a minute, maybe it's left cick then click the 'drop up' menu' ? It's menus, with dialogs, with more dialogs, with tabs, with buttons. It's absolutely bonkers but people seem to accept it.yeah if you are bitstreaming you have to find the one where it shows 5.1/7.1
windows 11 does seem to have menus upon menus to do what you want.
Bring back Win 95!
I use startinback to make 11 look like 10 start menu. 11 SM is horrid
Pragmatic. I stayed on 7 as long as was possible and switched to 10 as a last resort.The cycle is complete.
The once hated Windows 10 is now the Windows people cling on to.
I'm going to be that guy, i think the words you're look for is when it was a personal computer.It brings back the days when your OS was YOUR OS and you can tinker as much as you want.
It's not really opinion. There literally is all those menus i named, the worst being a 'sounds' menu option after i Click the sounds systray icon.It's just opinion of course and maybe I'm just used to it. Neither the 10 or 11 Settings app is great, I just happen to like the look and feel of 11's a bit more.
if not opinion it's fact. I'm not talking about your or my preference. I talking about the plethora menu options when trying to configure sound.If it's not opinion, what is it? I prefer one thing out of two options and think it's a bit better, you prefer the other. Exactly the same about most things in Windows, some like things about it others don't. It may shock you but some people even think 11 is better than 10...![]()
