- 6 Sep 2016
I'd pick any audio geared dac/amp over these creative gaming ones that may require prop drivers/software really, something like the Fosi Audio K5 Pro?
Easy return to Amazon too if you don't like it.
Stereo is easy enough, USB DAC/pre-amp/headphone amp/speaker amp etc. Probably good idea to shift away from optical/coaxial/hdmi audio as USB is universal enough USB ports on a computer.
Issue is multi channel audio, I still use optical out and will be for a while as HDMI audio is flawed
Side mounted headphone socket?! Also gotta guess how good the DAC side of things is as not all DACs are implemented equally, and no OpAmp rolling means no means to fine tune the sound if needed.
