Mod chip? Xecutor maybe?
I think i have found it... I think it is a X2.6 XEcuter Chip - Console has to go but thought I should know what it is im dealing with here
Well I won't say it was easy (desoldering is the devil's work) but I got the sticks in my dual sense replaced with the tmr ones from Aliexpress. It probably took me as long to do as it takes @Vince to repair half a dozen consoles...
Funnily enough I've spent some of yesterday and this afternoon trying to rescue an old Dualshock 4 (2019 but never realised it had drift from new, so pretty immaculate) but with no success. Was planning to solder in Gulikit TMR modules but for whatever reason; my lack of skills, or equipment I've struggled to remove the sticks from the board. Also had an older broken V4 Dualshock but I think I ruined that too. I think I'd be OK at soldering but removing existing parts is seemingly beyond me. Did watch a few Youtube videos but didn't change the end result.
So for now my adventures in trying to fit Hall Effect sticks is over. Also didn't realised how hard it is to find new, official Dualshock 4 controllers. Sony has quietly discontinued them and the usual places are rampant with fakes.
Nice.
Nice.
I've managed to source a new Dualshock 4 and want to fit a PAXO battery (easy not an issue). But I'm clearly struggling with removing the ALPS sticks. I tried wick and one of those cheaper suction pumps but didn't work. I assume the next step is to buy a vacuum desoldering iron, which are around £35. loathed to do it if it isn't a fairly easy/solid way to remove solder.
Are you using a desolder gun?
Wil say in advance, apologies not a regular in this thread in case alreadyy covered.
Ah OK. I that's where I take it where the tools can be quite expensive.nope I use hot air and a pump![]()
Hard plastics are good for a dunk in warm water with some dish soap, then rinse. Rubber pads should be okay, I would have thought IPA is more likely to make them sticky.
Ooo Crystal Xbox, Vince finds all the nice stuff.
Yeah, removal and cleaning was a royal pain. I did actually cut the stick cages apart with pliers, just so I could then do a heatwave a few pins at a time and wiggle the sections free. A better blade shaped tip would help too but turns out you can't get them for the Parkside irons.
Hot air that is suffiecent for the controllers is not that expensive. Cheap 858d clone that costs £25 or so is enough to for controlles. I used that for my dualsense.
My station is pretty expensive but I did years on a cheap 858d clone that was about £25 from china. I'm now using an Atten ST-862D which is a brilliant bit of kit. I use that to get the old stock out and just my iron and pump to clean up the holes. I did a video a few pages back on how to do it with a cheap pump and basic tools though.
PS5 pad boards are pretty thick so can take a bit of heat so you can work at 420c to 450c on them.
I do tryIn this instance though it looks like the chip is probably worth more than the console. It's a pretty cool thing and the mods look nicely executed.
I found two 858d clones each for around £25. I've also gone back and found that 72W soldering station linked in the thread for c.£25. So for both it would be £50 or so, which would significantly improve the tools I'm using. I also found a 2-in-1 SMD Hot Air Rework and Soldering Iron Station for £55 but I would assume the two earlier units are recommended given they are seperates.
I've already spent over £100 on helping hands, wick, blue mat, sucker and other soldering bits. In addition to the TMR modules and aftermarket PAXO batteries. Add on the above and I'm probably in for 3 brand new controllers already! But part of me wonders if I can do this and I still have some other older (broken) controllers around to test on if needs be (a DS4 V1, Xbox One controller).
- If I did go ahead and get this heat gun is it as simple as setting the temp at around 380-400C for 30 seconds, or so and the old ALPS module should just fall out?
- A few Youtube videos mention Sony's use of lead-free solder and how this is difficult to de-solder so they add some leaded, or low temperature melting solder first and then use the wick, or heat gun. Should I also be looking to buy some leaded solder too?
- Also what temperature should the soldering iron be set too when either using wick, or soldering the connections? One Youtube video said they have to run a high temp of 450C but this means not spending too much time so as to reduce risk of damage.
Thank you for the all the pointers so far and putting up with my many newbie questions.
I have done a grand total of one Dualsense, but it went fine, Vince probably has better tips but for me it was.
400C on the air temp with airflow at somewhere between 4-5 (sorry can't remember exactly). About 2-3cm from the board in sort of a circle motion over all the pins. Then when it was ready the stick didn't just drop out, it needed to be pulled, but basically no force, it just slipped out in one go. I also covered the plastic connectors in foil (whether you actually need to I don't know, but it was my first go with the hot air, so I played it safe).
100% get some leaded solder & add it to the points, easier to work with, lead free is awful. Shops aren't supposed to sell you leaded solder anymore unless you are a "professional" (a lot of the big electronic sellers just lock it behind business accounts), so you either have to import yourself or just get whatever random brand you find on ebay or smaller shops that don't care.
I don't get on with wick (at least for clearing holes, never have), I used a solder sucker to clear them. My iron was at 400C with larger tip to clear them with the solder sucker and and same again when soldering the new ones in.
Thank you that's really useful guidance.
So basically it's convenience vs cost; a heat gun is just going to be much easier than the chopping apart method, but also more expensive. I need to decide if it's worth it.
I have found a few sellers with '60/40/Tin/Lead', or similar. One has a skull branding with '63/37'. Is this OK, or do I need to keep looking?
EDIT: after botching up the 2 DS4's boards I then tried my attention on a 3 year old Dualsense with stick drift and again struggled with removing the solder. Tried to capture the stick I did remove but it looks like the middle of the 3-pins for the left sensor now has a burnt pad (for want of better term) and so is this board a lost concern?
Im going to do a ps5 pad after this xbox im working on so ill do a quick vid![]()
Its another one of those cool specials that makes a custom noise when you turn it on and off or eject a disc![]()
Thank you & much appreciated. I will definitely watch it.
I've managed to pick up a cheap, used Dualshock 4 so now have two V4's en-route (one new, one used), my original 2014 V1 will battery issues, a Dualsense with the above board, another 3 year old Dualsense which is already getting loose on the right stick (blame Division 2 for this) and an old drifting Xbox One controller. So lots to work with as I never threw away old Playstation's controllers. I also have the case/shell and internals for the two V4 Dualshocks I mucked up. So real potential if I can learn this.
Nice repair.
That was my second Xbox One X after my first one died 18-months in. Microsoft back then did make some wonderful special edition consoles. I also had the Halo Reach 360 with the two custom noises for start-up and shutdown. Also that Gears 5 Xbox One X had one of the nicest, if not the nicest special edition controllers too - which if I remember they sold separately too.
