Straight overclock lifts the entire curve, so you lose the granularity of being able to specify what frequency to hit for a given voltage.Isn't straight overclock basically undervolt (sans a cap on voltage) with nvidia? At every given clock it would use lower volts
It's very far from ensuring you're making the most of your gpu.
Out of the box you might need 1.000mv to reach frequencies your GPU can easily do at 0.9mv.
It's like going under a waterfall just to fill a cup with water. There are better ways.
