Reliable places to buy keys
27 Mar 2016
Bristolian living in Swindon
Hi all,
I'm looking for other sites to buy PC keys from, I use CDKeys but see a lot of others advertised but not sure what they're like
Thanks
I've done OK with InstantGaming as well.
I do occasionally use some of the above mentioned "dodgy" cheap key sites as well, but I do always go into it knowing that I might lose my money.
Fnatical, Green Man Gaming, CDKeys, Humble Bundle.
I'm probably missing one or two, there's a lot of dodgy key sites out there however and I tend to stick to the above.
I normally use cd keys but haven’t heard of the other ones you mentioned before, might check them out the next time I’m looking for games
They're all legit and authorised key sellers so not grey market/dodgy.
Tbh CDkeys is a little borderline in that regard, but it's by far the best of those that you could argue fall into that segment.
I tend to avoid anywhere that offers 'protection' for an additional cost when purchasing your cd keys or places that sell accounts rather than keys.
Usually you can tick the off and the keys are fine. Over the years I've bought plenty from Gamivio and G2A without issue, except 1 time a G2A code got revoked. Typically cheaper than CDKeys on humblebundle scalped keys. But remember to tick no protection.
No thanks, they might be safe but would rather not take the risk.
Lists all the sites .
Including places like G2A, which at least one indie dev has said that if you're going to buy off marketplace key sites then just pirate the game as it doesn't cost them money.
