The reason the Nitro has higher core clocks is because it is using 10% more power as standard.  Those extra core clocks are worth about 3% extra performance.  10% more power for 3% more performance is not my idea of a remotely good trade off.  When I set a higher PL, the avg core clocks go up.  It’s how it all works and why the Nitro is more expensive.  It’s always been the way with the OC cards that have higher power requirements.
I’m sorry but this is all made up nonsense about throttling etc.  even your own link tell you throttling isn’t an issue. Mine gets to about 88c under very long gaming sessions at stock.  With my more efficient settings it hits about 84c.  I can set a more aggressive fan settings and it will max out at 80c.
Show me where you found evidence that a 9070 XT pulse is throttling due to VRAM temperatures please?
Because I can assure you it most certainly does not throttle because of VRAM temperature, even if I push it to +10% PL and let VRAM sit at 90c or even 92c for longer periods.
Techpowerup show a VRAM temperature difference of 3c between a Nitro + and a Pulse at normalised noise levels.  77c Nitro + and 80c Pulse
				Sapphire’s Radeon RX 9070 XT Pulse trades flashy extras for substance, to hit its $600 MSRP. There's no RGB lighting or factory overclock, but you get an outstanding cooler that runs whisper-quiet at full load with good temperatures. Performance where it counts.
					www.techpowerup.com
