Gen 1 QD AW3423DW was replaced a handful of times for burn-in as some know
So just to confirm this toggle should be OFF in 10 bit mode?Thanks to a comment on reddit, this is now fixed!
If you are in 8-bit mode then the automatically manage colours for apps setting is off by default, it only turns on when switching to 10-bit, so you just have to turn that off. Seems this toggle got activated recently somehow, maybe from the recent Windows feature update as Ive had 24H2 since launch and never saw an issue until this recent Patch Tuesday:
No obvious signs of burn![]()
Do you do anything particularly fancy to mitigate burn in? Hiding task bar, desktop icons or do you just rock it normally with the usual monitor OLED care features and see how it goes?Here is my QF burn in progress, delivery was July 11th 2024, I use it basically 7 days a week, 5 days a week are working from home, the evenings and weekends I am gaming, editing and generally browsing and doing other working. This is very heavy usage and my Gen 1 QD AW3423DW was replaced a handful of times for burn-in as some know.
No, as long as your GPU is powerful enough. Even if there is tiny tearing, it's not noticeable as things are so smooth anyway vidually.In regards to VRR rlicker. If GSYNC is disabled and frames are uncapped is screen tearing a problem on these oleds?
I've seen no issues with Gsync off, only benefits months later with no flicker in anything.
Enable a global fpsbcap of 223-235fps, and cap individual games of desired. That's all that should be done
Looking at the Alienware 32 4K QD-OLED . Has anyone mounted one on a single monitor arm , any issues? Just can't makeupmy mind , this or the ASUS ROG Swift OLED PG32UCDM. Decision Decision?
