My Gsync operates down to at least 20fps. I can see my monitor refresh rate in OSD matching to FPS and ive seen it hit 17Hz.No.
No offence to mrk but rtings are pretty reputable including pcmonitors.info and like my own videos show the flickering of the aw32 where as none on the aw34dw, yes there might still be some on the aw34dw under certain scenarios but it is certainly not anywhere near as bad as every other oled as evidenced in rtings findings (if you're coming from an ips, you may notice it more or may not). The aw32 and other non gsync ultimate monitor will most likely flicker in "every" scenario when you get close to the starting VRR bracket where low frame compensation kicks in i.e. usually around 55-60 fps (gsync operates all the way down to 30 [which is also why anything between 30 and 60 is far smoother and more playable than any adaptive/free/g sync compatible display).
I wouldn't get an aw34dw now anyway regardless, it's first gen qd-oled and if you have waited this long, you can wait a bit longer until the new gsync displays come out using the mediatech scaler.
The problem is, there's always new tech around the corner. If VRR and screen burn were no issue for OLED and text clarity was the same as IPS/VA/TN then id be 100% on board.
I use my screen for 80% productivity with 20% gaming (maybe an hour a day on average for gaming) I say 'productivity' - forums, discord, youtube mainly. Hardly being productive
