Agreed. Both go hand in hand if you want to get the most from your card. It’s definitely not an either/or situation.I don't get, what people don't get, about undervolting/ overclocking. You can do both at the same time and double win.
The daily conservative undervolt + overclock profile I've settled on for my 5080 is 0.91v at 2950Mhz core and +1400Mhz on the Vram (Default core volts are ~1.01v and core clocks 2750Mhz).
So I'm overclocking AND undervolting, and get more performance Vs stock whilst shaving off about 80watts of power which results in less heat and noise. What is not to like about this?
I've also done a super aggressive PBO undervolt / overclock setup on my 9700X (superb CPU by the way) so it runs at low volts whilst boosting all cores to max. Again, more performance Vs stock whilst drawing less power, and having less heat and noise. My air cooled rig is really quiet now and flies.
I really want to reduce the voltage more for my 24/7 clock speeds and see if I can unlock more headroom but it’s so demoralising and time consuming when it crashes and you’re on the limit that I think I’m just gonna leave it where it is
. Mine runs at 52-60c and doesn’t hit close to 600W except for Steel Nomad. Anyone else sniffing their power cable for burning when it’s maxed out?
. Got the Astral LC 'just now' so not needing to worry about the power cable due to the monitering, runs well within spec.
