- 4 Aug 2007
- Wilds of suffolk
not in the uk you dont thats very misleading that pictureso you just plug it into a wall socket and it'll sell the leccy/power the home in reverse? wow
ah ok lolnot in the uk you dont thats very misleading that picture
the base of the turbine doesn't look very weather-proof how does it get mounted outside?not in the uk you dont thats very misleading that picture
yup 40x aiko panels, east west split. Sigenergy gateway, 24kWh battery and 10kW inverter. Installed Nov 2024, so still new. DNO unfortunately limited to 10 to 8 by SP Energy. Single phase. We are high electric users comparatively so I don't anticipate too much clipping.How big do you want to go https://www.solartradesales.co.uk/solax-x3-forth-136kw-three-phase-inverter?cat=9741
Actually considering the size that's surprisingly cheap!
I've got an 8kW and 3.68kW inverter.
I think @f666 recently had a 40 panel system installed, I think he went with Sigen Energy, but there is a wide choice of inverters, with the largest single phase inverter apparently being this 16kW Sunsynk inverter.
I wouldn't waste you're moneyso you just plug it into a wall socket and it'll sell the leccy/power the home in reverse? wow
I'm buying a house and it has some 16 solar panels on its roof, when I asked about the setup they told me they export all their surplus to the grid and I was wondering if it was worth while investing into a large storage battery.
Also what maintenance do these panels require? FR m what the seller have explained to me this solar system they've had in place for the last 9 years is the greatest thing since sliced bread bit I'm thinking it can't all be strawberries and cream. Is there anything I need the be a aware of?
I wouldn't recommend them either.So, an update after 18 months of my solar panel install.
I have had major issues with pigeons, even though I paid for and had fitted (poor job) bird proofing at the same time as the whole installation.
Have tried multiple times to contact the installer (My energy solutions) and have just been getting the cold shoulder, they have even stopped responding now.
Whilst the original install, etc appeared to be great, if you have issues going forwards they have just pushed me back all the time and I can't recommend them for CS.
Shame really, as they have missed out on other installs due to this as I have told people to steer clear.
The key point isn’t the outlay but the RIO.Personally, as someone who is thinking about getting Solar, it would be nice to have a outlay vs your income so far and over what period. I know I'm asking a lot
M.
My system cost £16k but it’s quite large and has features you do not need like grid islanding and whole home back up in the event of a power outage.
However, it will fully pay back in under 8 years. You can get the same system today for 15-20% less in cash terms as prices have dropped recently.
You also don’t need a south facing roof, none of my panels face south, I’m directly east/west with some shading on my east roof in winter.
If you are south facing, I would also cover the north facing roof. The return on solar panels is higher the more you get because installation costs are largely fixed so the more you get the better.
Batteries are the opposite once you have enough, adding more reduces your payback period.
Truncated quote for convenience.Thanks, M.
Batteries come in all sorts of sizes and makes, I built my own and have 29 kWh of storage.Thanks, I won't quote because it is getting messy. Good to know, any details about the system such as the models, batteries, etc. assume the batteries drain at night and recharge in the day? Or do you have them constantly charging via both solar and grid? How much charge do they hold?
Thanks!
M.
