- 22 Aug 2005
- Clydebank
Sounds like you have network loops/bridgesJust a mad latest update .... where to start?
After reading the good advice about Sonos & STP, we did some testing and checking. As mentioned, there are some well documented issues about mixed Sonos wireless and wired networks.
Anyway as part of this testing we measured the speed on a wired desktop PC to the internet with a long standing Sonos Play 5 connected to a port on the Netgear switch and then to router. This is what we saw .... ahh .... I can't see how to link an image from the PC I'm typing on .... strange. It only allows from media sources not the device?
Anyway, basically with the Sonos Play 5 connected we saw near 900mb internet connection at the desktop PC.
When we disconnected the router but the Play 5 still wired to the switch .... we still see 4mb connection to internet. But the Play 5 has no wifi or bluetooth functionality. It can be wirelessly connected to the network.
And when disconnecting the Play 5, and the router, there is of course no connection.
Very odd.
You need to draw out your topology like what was suggested In the first post
