Morning folks
My system was built back in 2018 it’s a Ryzen 7 2700x in a auros gaming 5 board and an aio cooler.
I’ve upgraded a couple of bits since 2018 and its now running 32mb of ram a 6800xt Gpu, a newer psu and an m2 ssd
I’m looking to upgrade the processor and have a couple of options but not sure which way to jump.
Do I just shove a new cpu in or upgrade the board and chip to AM5 (along with memory)?
Friends have suggested that I should look to replace the aio after this much time either way, so the list of bits to replace gets longer which makes me consider selling the pc as is and putting money into a new one entirely.
The other consideration is I’ve never replaced a cpu before, nor installed a motherboard and not sure how easy it really is, I know lots of you will say it’s simple to do but having never done it I don’t want to screw it up.
If I’m looking to upgrade what would be your opinions/options on what to do. Budget is £1500 for upgrade excl gpu (assuming the gpu is still good enough for now)
