- 21 Jan 2010
Quill and parchment
Chisel and stone block.
Quill and parchment
If anything happens to me, I don’t expect someone else to competently use a CLI to extract filesWhy not upload it to s3?
Guessing you aren't a tech then![]()
lol I'm actually a senior dev / tech lead. We have loads of critical stuff running in Azure and don't really have any issues with it either. I do generally prefer running stuff on Linux there though because it's cheaper. And I've recently switched my work work machine to a MacBook Pro because I got sick of the terrible performance and battery life of Windows laptops, so I'm pretty balanced![]()
If anything happens to me, I don’t expect someone else to competently use a CLI to extract files![]()
Azure is just all the same stuff we had before, but long winded and more annoying to use :/
And also now really expensive, so some companies are getting rid of it again!
How much space do you need?
I just use the lowest tier iCloud now cos I only really store photos and a few documents as well as the back up of my phone. Currently using 5 out of 50GB for 99p per month.
Even they deteriorate! Mum's got some old photos of my grandparents the photos have faded badlypen & paper
Like any cloud provider it's a pain if something does go wrong and you can't fix it because it's somewhere in the Microsoft/Amazon or whoever side.
I guess the tradeoff is you're not paying for your own hardware and 24/7 on-call network engineers to look after everything.
I think we're paying close to £30k/month for our cloud stuff, and I reckon I could half that by just optimising all our resources if I acutally got the time to do it (most was set-up by other people before my current company bought my company out).
You can encrypt it yourself if you're that concerned, but the terms and conditions of the provider will be quite clear about access to your data.For those storing stuff on the cloud, can you really be 100% certain that the host isn't using it to train their AI?
30k a month.. cheaper to hire your own guys and build your own network tbh![]()
