The Radeon RX9070XT / RX9070 Owners Thread
Weirdly the 5700x3d top 9070xt score is higher with 8131. So in theory 8100+ is possible with the AM4 platform.
i found my score a lot lower going from 13th gen to am4 (9070 none xt)
i put this down to pcie5 to pcie4
They are an outlier. 2nd place is 8030 or something. They must have used cool air or are some kind of OC genius.
I need 8048 to top my table. I don't stand a chance. I'm nearly 200 points off!
it could be your CPU i lost 3000 points going 13900k to 5700x3d, also pcie 5 to 4
still a very good score
it could be your CPU i lost 3000 points going 13900k to 5700x3d, also pcie 5 to to4
It may be CPU related but my 13700k is pretty decently overclocked and running with very good ram for the CPU, 7400 cl34.
I'll try fixing the frequency to 5.7 all core when I get chance and running again. Maybe turn off the e cores too.
Edit: I'm running 24gb ram sticks. I think I read somewhere that these perform slightly worse than 16gb due to some secondary timings. Maybe it's this.
my 9070 was benching at 30100points(better than a few bad XT's) but now i cant pass 27500 about right for a good none XT
but like you say it was a 13900kf/6000mhz cl28, now 5700x3d/3600mhz cl18
TBF in game it still hits the same frame cap and runs cool
Yeah in Timespy it definitely favours intel CPUs.
this is the best score i ever got with the 5700x3d, just did that now trying to push hard
None XT? that's impressive.
RX 7800 XT, Sapphire Pulse. OC to 3.0Ghz, up from a base clock of 2.43Ghz.
Graphics Score: 4639.
You're 50% faster than me.
yer my 9070 runs at the same speed as a stock 7090xt or ever an few overclocked bad cases.
the nitro+ really his a big hitter
the X3D will be helping with steal nomad
@Kirkatron something that may help you.. i dont know if windows 11 dose it but in windows 10 there was a way to make it run on basic services.. it would make it look like at only windows 97 pc hahah but it removed a lot of the OS overhead
all the overlockers used to do this to push for very high scores. but i dont know if it helps GPU's
also remember trikes like setting the fan to fixed 30% remember the fan pulls power too, when i had 2 x 290's with the fan fixed i could push the core 150mhz more for short benchmarks
if you have thermal headroom limit the fans.
Interesting. I'll have to look into that. Typical, I just updated to win 11.
it could be an 11 thing too I've not looked, i used to try a push GPU scores back in the day but now days i just drink beer and watch you lot do it hahaha
Hahaha well normally I drink all the beer and just read these forums but thought I would try it for once in my life.
I guess now I'll drink beer and try beat my score! Then after that I'm done. Maybe.
google says....
To optimize Windows 11 for benchmarking, you'll want to ensure your system is in a "basic" or "performance-focused" state. This involves disabling unnecessary features, services, and background processes that could interfere with accurate test results.
the problem now day is some GPU's are hand picked to send to board makers, i remember running 2 BUDGET x 7950's that i got from OcUK for £100 each in a stock sell off that wear monsters, but now days there is no budget GPU that can push hard.
it takes the fun out of it, like my 7090 nitro+ i paid what you can now buy an XT for. but its a good GPU if i got the budget 7090 as you can see from this tread most are complain about under performance
google says....
I tried all that, I'm assuming my windows install is a bit bloated as it's about 5 years old. Maybe more.
I'll maybe just stick to drinking beer again.
i can get about another 100 ish in a single run by going a fair bit further on the uv an oc BUT it consistantly crashes to black screen that only powering off fixes at around the 17th or 18th run so obviously that isnt stable lol but this is able to do the 20 runs at least
-45mv +40mhz 2738 vram [2744 in memtest vulkan was the best i could get but im suspecting that extra 6mhz is the cause of the crashing might be the slightly higher oc and uv on the core probably the combo of all 3 lol
