what does your OBC say, if it's >3000 miles leave it aloneThe discs on the front are fine. Almost look new and look like originals on there , slight pad wear , rears look ok, slight bit of corrosion compared to the front . Do you need anything special for the efficiency dynamics?
non-runflats definitely, and the usual suspects (though you might not need the performance on a 20d lol)Also to anyone really , usually I would ditch runflat tyres as on previous cars Iv owned they had been really rough on.thr road and noisy.however the 420d I have they don't sound too bad..hardly any noise really and it feels comfortable..
If and when they need replacing not sure if I should go non runflats or stick to runflats
front pads are usually changed first, so the rear is likely going to be the ones from the factory
i went with non oem brembo pads when i changed my front
discs usually last 2x brake pad changes
usual suspects = mps4s/ps5, csc7, assy 6
(pz5 not yet available in bmw staggered sizes yet
just get the cheapest of the usual suspects whenever it's time to change the difference between them are negligible for easy day-to-day drivingCheers on tyres I'll take a look.
(would usually be the csc7 or the assy 6)
if you get RFTs then the general understanding is that most places won't repair a puncture as they cannot guarantee the integrity of the sidewall if it's been driven on when puncturedI have to traverse stretch of road which is bad with road metal fragments on the way to the office. Iv had some bad experiences with tyres
not too sure about mid range tyresI usually aim for mid range
the "usual suspects" are UHP/UUHP tyres and are priced accordingly
are you on 18 or 19 inch rims?
The ones on the back are 225/40 R18 so 18 ,
sound deadening is probably better on the 4 than the 1I thought the bigger the wheels the more noiser it gets but its quieter than my old car
Would expect either 255/40R18 or 225/45R18 for that generation of 4 series, 225/40R18 sounds wrong
One of my mates told me about them, when I asked. Must be a sign, I'll have a look. CheersHave a look at Gliptone.
Colourlock cleaner and shield kit.What leather conditioner could I use to put some life back into the Dakota Black leather seats?
Edit: Typo fix, I swear the autocorrect is getting worse, not better... lol
Why, it’s one of the worst examples on AT for the age/mileage.Going to look at it tomorrow
