- 25 Apr 2012
- Oxford
Bit surprised by that but fair enough.Gotta be liquid metal on the ps5. Was liquid metal from factory, overheats with normal thermal paste.
I've done 4 so thought I would sit and play a game. 2 with normal sticks, 2 with halls.
No idea on the dead ones. Ill let you know.![]()
There is a place with reasonable reviews, will try and take it to them this or next week, they said they can look at it for free before doing any work.Could be easy could be hard. Had a similar one a while back and all that it was was a 1.8v mosfet that died. Swapped the fet and it's been great ever since.
It's a shame there isn't a local reliable place you can run it into for a look over, it could be something pretty simple.
@Vince any chance you can help with my rtx 3090 issue? I started a thread in the graphics section but unsure how to link to it here
That is lovely. As you say better than Sony's Pro controlller and a great way to extend the life on something.
I knew of Extremerate back button mods having seen them on Youtube before, but last night went looking for this one and there are loads. Different colour ways galore which match many of Sony's different colours.
I also found out Extremerate do other mods such as the clicky face buttons, tactile bumper/trigger buttons and extender kits so the modded controller can still be used with the official charging stand. Very cool. I'm not that keen on modding the haptic triggers as that is one of the strength's of the Dualsense but the back buttons and clicky face buttons look cool. I wasn't going to do it but seeing yout controller has given me pause for thought.
.It also has a massive dry spot on the apu where it's spent its life standing up so the top of the apu was dry. If you are one of those stand it up PS5 people and it's an early PS5 I recon loads of them are like that certainly the last 3 or 4 I've had all had dry spots on the apu.
. I thought the dry spot was just normal console argument nonsense. I have mine horizontal, so no worries there, but odd that Sony let you stand it up if that's going to happen.I forgot to reply to this. Yeah they do loads of colours, your colours are a bit more limited if you go for RMB (metal backpaddles), technically you can buy the plastic version and then buy the RMB upgrade seperate, but I like matching paddles.
That's a real thing. I thought the dry spot was just normal console argument nonsense. I have mine horizontal, so no worries there, but odd that Sony let you stand it up if that's going to happen.
How's about turning yer PS5 upside down for as long as you've had it up to that point?
This is a genuine real thing the liquid metal runs down pools at the bottom and leaves the top of the apu dry... its mental.
Not much Sony can do about it running, but I'm suprised Sony let you stand it vertical.
Does I cause issues? I would assume it makes it run hotter/hot spot and gets the fan going a bit more.
I have had a little look I doubt the cap would be the reason that the fuse went... most of the fuses on these cards I see are zero ohm resistors. got some pics of whats gone?
17447374664337432338024204349090 hosted at ImgBB
Image 17447374664337432338024204349090 in the Screenbeat's images albumibb.co
17447373966357889921053334380719 hosted at ImgBB
Image 17447373966357889921053334380719 in the Screenbeat's images albumibb.co
17447374494805576028998434907463 hosted at ImgBB
Image 17447374494805576028998434907463 in the Screenbeat's images albumibb.co
Hi Vince, thanks for the reply photos show the capacitor and fuse I want to replace. I'm just trying to find out what the fuse voltage rating might be.
58 ohms I think it's reading across the fuse. Honestly I just saw the bloated capacitor and just hoped that replacing that and the fuse would get it working again. Issue is nowhere I look states voltage ratings for these fuses, just size and amps.Well the fuse looks to be on memory so it wont have a massive rating. looks to be 20a 12v fast blow but honestly if its blown id probably just bridge it for testing. What resistance readings you got either side of that fuse?
Cheers Vince, I'll swap out the capacitor and see how it goes. Thanks for your time.Hmm I have a feeling its not just the cap and fuse. I mean it could be and you get lucky but id wager something else is at play here as well... That might be because of this 3080 I have here with similar symptoms that is just dead but you might get lucky.
Personally id replace the cap, bridge the fuse and just measure the line again and as long as the line wasnt dead short id just try it. if it works id just stick a 20amp fuse there and be done with it..
Looks like the Xbox 360 Street Fighter IV joypad in that box. Used to have that and the PS3 variant (PS3 was wireless with a dongle). The rubber had started the process of going 'tacky' on the back of mine, or at least felt different from when they were new.
