Had mine since ~25 Nov 2022 and the NIC worked for ~6 months. Maybe newer boards are fixed?Intel NIC still working great here, I only use wired internet (1GB connection) , FYI had my board since Oct 2023.
I checked mine with cpu-z, comes back at FSB-DRAM 1.30, no idea why as ram is running 2999.0 MHzCould anyone give me a little advice on what to check in bios to make sure that my 9800x3D is 1:1 with my DDR5 6000?
I had a quick look and couldnt find anything obvious.
On my other PC with an Asrock mobo, there is a specific ratio setting listing in bios fclk:memclk (or something similar) 1:1
Cheers
Cheers
Cheers, I'll have a look when I'm on my pc later.In bios, use search at the top and type memclk. This will bring up the setting to make memclk=uclk
New bios out with performance improvements.
Think I'll wait, a beta BIOS and Asus does not exactly have a good reputation where those are concerned.Why does WCCF have Google drive download links to a version ASUS doesn’t have on their site?![]()
"Performance improvements" could mean anything. MSI BIOS lists improvements in certain RAM configurations, so it would not mean for everybody.
