Man of Honour
- 5 Jun 2003
- Falling...
Easy to fit? Looking at an intake for my Superb.
I'm quite handy with spanners. It's either this or the REVO variant - the Superb already has the REVO map so leaning towards but keeping options open.Very easy took me less than an hour, I'm sure the superb is not too different. If you're relatively happy with this sort of stuff it's basic.
The trickiest thing for me was getting the vacuum hose off the original airbox. Taking the original PCV off was a little tight but putting it onto the new elbow was a doddle.
I'm super happy with the mod and the driving characteristics it has offered. But mainly it's the sound.
I'm not sure MST do a 3b EA888 system - 3b's having a MAF. Couldn't tell in there pictures.
She does like to spin up the fronts. Unsurprisingly if the roads are wet a little too easily.Not sure there I'm afraid. I also have the EA888 engine (DKTB) but there may well be a variance with the Superb. It was either that or the RacingLine R600 which looks similarly OEM but is a little quieter / less aggressive. Both connect to the original air feed neatly though.
Go with what you feel is best. Certainly brings the car to be more chatty which is nice.
Nearly 300bhp through front wheels though is probably a bit too much but part of the fun!
Hate to say it, but you're going to need to get back in there and actually lubricate the bearing.Sprayed some WD40 on the bearings on the replacement Denso unit to extend the life of it, swapped the final stage resistors over and fitted it. Instant cabin air back again, just in time for 20c+ this week. I gave the old one the same WD40 treatment and left it overnight, and it spins the same as the replacement part now
happy.comFitted a "tracking device" to the eldest's car for the insurance company.
LIVE GRENADE!Nothing makes you concentrate harder than using spring compressors.
