- 21 Jul 2005
- England
dont 5090 use different liquid chamber than 5080 for the main GPU? from Gigabytes statements its not a issue. If my card fails I will return to OCUK in 30days or RMA.
I believe the 5080 and 5090 cooling set up is the same but I don't think there's anything to worry about tbh. I had no issues with the Aorus Master 5090 in the month that I had it.dont 5090 use different liquid chamber than 5080 for the main GPU? from Gigabytes statements its not a issue. If my card fails I will return to OCUK in 30days or RMA.
There’s counselling for this, this is actually strange behaviour2 Suprims, suprim liquid x thingy, gaming trio, Astral LC that 5 so far. But 2 coming on Tuesday. See how I battling my gpu collecting addiction. Like a total boss not....
Did you not buy a Godlike motherboard yourself? You may need the same counselling you are advocating. Let the man spend his own money how he pleases. LolThere’s counselling for this, this is actually strange behaviour
Godlike vs how many GPUs, godlike features getting used btw - very different conversation.Did you not buy a Godlike motherboard yourself? You may need the same counselling you are advocating. Let the man spend his own money how he pleases. Lol
Any movement on your Lian Li wireless fans?
Some people will consider you spending over a grand on a motherboard to be absolutely crazy (I have got a Godlike too as you know).Godlike vs how many GPUs, godlike features getting used btw - very different conversation.
Nothing on the fans, was close to buying originals from OC but the reverse are always on preorder so might as well wait for what I actually want
The point would be welcomed if I had bought 7 of the highest priced AM5/Intel boards. As you say people gasp at the Godlike board which isn’t even the highest priced mobo vs how much are 5090s I’m not even trash talking him I’m genuinely concerned, it’s strangeSome people will consider you spending over a grand on a motherboard to be absolutely crazy (I have got a Godlike too as you know).
If he can afford it and doesn't get in debt because of it, more power to him. Looking forward to seeing your build when it's finally done.
I wouldn't be concerned. Take it from me, he's definitely got the means to support the hobby.The point would be welcomed if I had bought 7 of the highest priced AM5/Intel boards. As you say people gasp at the Godlike board which isn’t even the highest priced mobo vs how much are 5090s I’m not even trash talking him I’m genuinely concerned, it’s strange
Wait you have an aorus 5090? That would make us Aorus twinsies.....white or black?I believe the 5080 and 5090 cooling set up is the same but I don't think there's anything to worry about tbh. I had no issues with the Aorus Master 5090 in the month that I had it.
I had one of the first black Aorus Master 5090s in the UK I believe. I passed it on to a relative and now have a Suprim 5090 myself.Wait you have an aorus 5090? That would make us Aorus twinsies.....white or black?
Fine then we can be suprim twinsies thenI had one of the first black Aorus Master 5090s in the UK I believe. I passed it on to a relative and now have a Suprim 5090 myself.
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
Haha! Yes we are!Fine then we can be suprim twinsies then![]()
Are you set on the Astral? Are you open to a Suprim?The real question is... Should OC be the new "carrier" of the FE cards instead of barcode? LUL They are fumbling quite hard
p.s - Im keeping my wallet and eyes peeled for the Astral this week. LET ME BEAT THE BOTS LORD
Thanks. Sounds like there may not be a huge difference between the Gaming Trio, Vanguard and the Suprim. Shame the prices are similar(ish).Suprisingly the gaming trio is the fave of my collection so far. Thought it was going to run way hotter than expected but was okay. Sure the fans are a little louder but i run a custom curve so the fans spin uo fastsr than what thyy should do at stock.
Also found with undervolting the gaming trio is more receptive to undervolting than the suprim. I have never found an undervolt i was happy with the suprims. But i am an undervolting noob.
Also the gaming trio did have a moderate amount of coil whine but for the most part it vanished/ or is so quiet you wouldnt be able to hear it over say case fans or gpu fans.
Last night it hit 2k fps on that new game expedition 33 and i put my ear to the gpu and there was not a peep but obviouslu in something like steel nomad or even worse monster hunter benchmark on the menu screens there is a small amount.
It is the card with the least amoint of coil whine in my collection atm.
Mine was delivered yesterday... temps pre under volt were 76-78 GPU and memory 88.After under volt its 66-70 and memory around 81. Performance in games appears to be about the same so I guess it's good and Steel Nomad benchmark increasing to 14760 from 14215. I have no idea if that's good or not as I usually don't bother with overclocking etc but I'm happy with it so far.I think you're the first here who i've seen with the Ventus. How are temps when gaming (either with/without an undervolt?)
I might, but the fella talked about having 2 and both having issues put me a bit off...Are you set on the Astral? Are you open to a Suprim?
Haha! It will happen for you. GodspeedI might, but the fella talked about having 2 and both having issues put me a bit off...But lets see if price wise is good
