What have you done to your car today?
Added a sealed air filter from MST and a new less restrictive turbo elbow. It fits like OEM and the induction sound is gorgeous can really hear the turbo much better which honestly was missing. The remap needs to be tweaked to match the changes but that'll be done for free fortunately.
Easy to fit? Looking at an intake for my Superb.
Very easy took me less than an hour, I'm sure the superb is not too different. If you're relatively happy with this sort of stuff it's basic.
The trickiest thing for me was getting the vacuum hose off the original airbox. Taking the original PCV off was a little tight but putting it onto the new elbow was a doddle.
I'm super happy with the mod and the driving characteristics it has offered. But mainly it's the sound.
I'm quite handy with spanners. It's either this or the REVO variant - the Superb already has the REVO map so leaning towards but keeping options open.
I'm not sure MST do a 3b EA888 system - 3b's having a MAF. Couldn't tell in there pictures.
Not sure there I'm afraid. I also have the EA888 engine (DKTB) but there may well be a variance with the Superb. It was either that or the RacingLine R600 which looks similarly OEM but is a little quieter / less aggressive. Both connect to the original air feed neatly though.
Go with what you feel is best. Certainly brings the car to be more chatty which is nice.
Nearly 300bhp through front wheels though is probably a bit too much but part of the fun!
She does like to spin up the fronts. Unsurprisingly if the roads are wet a little too easily.
Mine was dyno’d at 272bhp on 99ron.
Next round of tyres, I’ll stick something a little more sticky on it.
Attempted to sort the gouges the company motor picked up on the rear bumper. Turns out there is more to a decent repair than slapping on some touch up paint then buffing it back.
It's a bit better than it was. I might be able to get it better still if I have another go at it but I think I'll quit while I'm ahead for now.
Anyone who reads the BMW thread knows I damaged my front splitter last week leaving Stirling Castle.
Purchased an aftermarket replacement from eBay and fitted it this morning. Didn't think there was much point buying a genuine replacement, as I'll no doubt have to do it again.
Before
After
Got the oil hot for the first time in quite a few months. Goodness me I need to drive the car some more. Hard to believe the car will be 20 next year!
Fitted a replacement blower motor on the E92. The old one (which was obviously a cheaper aftermarker part) packed up and didn't work on any setting just over a week ago, although I suspected something was up for a while because some days it would make a quiet rumbling noise.
On removal of the old one, I found that it would bind up as I tried to spin it, so it likely had no chance of moving properly under its own steam. Sprayed some WD40 on the bearings on the replacement Denso unit to extend the life of it, swapped the final stage resistors over and fitted it. Instant cabin air back again, just in time for 20c+ this week. I gave the old one the same WD40 treatment and left it overnight, and it spins the same as the replacement part now, so I'll keep it as a spare even though it may just be properly dead, but I'm not playing contortionist under the dashboard again in order to test it.
Could do with adjusting the handbrake as well, but it is a job I never liked doing on the E46 because it felt a bit like luck of the draw striking a balance between having a decent handbrake while not having any binding with the handbrake off.
Hate to say it, but you're going to need to get back in there and actually lubricate the bearing.
WD-40 is EXCELLENT at flushing out lubricants by diluting them. When the WD-40 dries up or runs out of the bearing it will be a matter of time before it's dead.
You need something that stays in place and has a long lifespan.
Been tidying up Pops' car while he's in hospital as a bit of a surprise for when he's out (he's fine dw), tidying up bits of paint, new centre caps, etc. As well as a few little bits like drop links and whatnot.
Made the mistake of tending to the rusty front arches and things went from "I better get the filler" to "I better get the chicken wire" to "I better get the welder" real fast. :p
He's had the thing for 20~ years and has put 200K~ on it.
New rear brake discs/pads (Stop Tech Black series, PFC Z Rated):
A fresh scrape:
Gotta call a mobile smart repair dude I guess....
Spring went pop on the Mini so treated it to Bilstein B4 sport shocks (oem eq), new top mounts, bump stops, boots, droplinks etc. Job came in at £400. Battery also died, short trips and then sitting for 2 weeks finished it off so that was another £250 and half the engine bay out.
Nothing makes you concentrate harder than using spring compressors.
Rear shocks and brakes next.
