I am still on a 1070 as well, until my 9070XT Nito+ arrives, still one of the best cards I have ever owned but age has finally caught up with it.Tell me about it
I can barely run cs2 at low settings.
Looks like the Sapphire Nitro's use Samsung VRAM.Been trying to find a way to buy either the 9070XT or 9070 but with Samsung GDDR6 but so far the only way I can guess is either playing roulette or buying second hand
My two week old pre-ordered Nitro+ is Hynix. Is there a reason to want the Samsung other than reportedly slightly lower temps?
Fundamentally, nothing. It will run cooler and thus show lower numbers for those that run GPU-Z constantly.
My Pulse has SamsungThis article may help.
AMD RX 9070 XT Update: Transition to Samsung GDDR6 Memory for Improved Thermal Performance
The AMD Radeon RX 9070 XT has recently undergone an update involving a change in the type of memory used. Historically, the model has faced criticism for high temperatures associated with its GDDR6 memory, particularly in configurations that adhere closely to the manufacturer's suggested retail...www.guru3d.com
Looks like MSRP cards get Hynix, for the moment, and the OC versions Samsung.
Yeah I kinda need the samsung chips because of my setup and its thermal constraints
Yeah, its really a non issue. My Nitro + is Hynix. VRAM regularly hits 90 Degrees but zero issues, my old 7900GRE nitro hit 88 all the time, its all well within the operating limits of memory and if something does go wrong then they have a 3 year warranty.We're only talking single digit % for temp/OC between Hynix/Samsung aren't we? Wouldn't worry about it.
Poor QC with thermal pads could just as much skew either.
Could be. My asus Prime 9070 non XT sits at around 80. I'm not worried. I've owned a MSI R9 290 with the tiniest 2 fan cooler to ever be put on a Hawaii chip. 80 is pretty chill compared to that.I don't know if it's a thing with XTs but my non-XT Pulse Hynix rarely hits 80.
Perhaps it's an AIB thing too.
the hellhound sits around 45c with memory at 65-70 after a few hours of warzone with Hynix memoryI'm sure someone in this thread has a pulse with Samsung memory.
For reference, My OC'd Nitro+ memory temp sits at 68degC playing Warzone and GPU temp of approx 40C give or take.
my 390 used to kick out so much heat running hot as hell day in day out while I still played 4-6 hours a nightCould be. My asus Prime 9070 non XT sits at around 80. I'm not worried. I've owned a MSI R9 290 with the tiniest 2 fan cooler to ever be put on a Hawaii chip. 80 is pretty chill compared to that.
