- 24 May 2015
I personally don't think it's a good idea to keep sending back the *same* model in hope you get one with low coil whine which is possibly how people end up returning multiple cards.I knew I would trigger some people with my comment, but I fully stand by it. You also claim the Aorus 5090 has loud fans (vs other 5090 models), That's simply not the case.
Case in point:
You need to accept some electronic noise, it's more or less a given with these cards. Use an undervolt if you want less electronic noise. If your Aorus' fans are loud, you need more airflow in your PC case.
I've returned a couple of graphics cards over the last 8 years or so, but not many in a row. When I got a noisy Astral, I checked this thread (among others), and saw that Gigabyte had few complaints, so my second purchase - an Aorus worked out well. Of course you can be unlucky, but 4 bad cards in a row from "good" brands is a lot.
Maybe the issue is with the motherboard. Try the card in a friend's computer, and see how to works there.
Anyways, hope you'll sort out your coil whine issues, but let's drop the straw men.
. Just felt it was too expensive for what it was, comparatively. It will run a little warmer, a bit louder fans potentially, but better than coil whine?
