Where are you seeing 450w for £60inc?Commercial is totally different. Roof space is probably limited on domestic so you can't just chuck on 2 extra panels. 390w panels are old now anyway, 450w panels are only £60.
City plumbing.Where are you seeing 450w for £60inc?
Yeah East Sussexthat's expensive
are you down south?
do you need micro inverters?
Micro will be more effective on locations that may have partial shading. Do you have shade on some of the roof?Yeah East Sussex
It's the cheapest of three quotes, fourth company little green energy hasn't got back, sales guy said micro more efficient
Early morning, late eveningMicro will be more effective on locations that may have partial shading. Do you have shade on some of the roof?
probably not worth the outlay then, if it's at the start/tail-end of the dayEarly morning, late evening
I'd rather save the £600 using the 390w panels.
Which is why I'm using 390w on my garage. Then again, I'll move in 3 odd years
Search for "Adjustable Angle Solar Panel Tilt Mount Brackets Solar Panel Mounting Brackets"
Call your DNO, the issue will be specific to the transformer serving your property.
I'm just considering options for how to mount these panels on the wall. I'm likely going for to go a 3x2 grid in landscape and that's got me thinking about brackets.
1. Mount the panels individually? i.e 6 sets of brackets.
2. Join the panels (3 lots of 2) i.e 3 brackets with a centre join on each pair of panels
3. Join all the panels together with the appropriate bracing? (3 bracket sets along the top and bottom of the 6 panel block)
Option 3 seems preferable from an adjustment perspective, 1 seems best from a sensible weight load per bracket perspective and 2 seems to be a happy compromise.
Or does it really not matter?
