- 21 Dec 2019
- Planet Thanet
It's possible to diy a leak tester
Not sure how much you would save though
It's also possible to diy a vacuum pump
Both fill and empty using it
Think the leakshield can do similar
Though those aren't cheap
and the standalone version thats not on their reservoir
has caveats where and how you fit it
and calibrate it
But yeah for donkeys years
Just did the power the pump from psu
With nothing else connected
And little bit of washing up liquid around where fittings
Meet tubing etc
and calibrate it
Meet tubing etc
