Couple of days ago I noticed only one of the tail lights on the wife's X3 was working but there were no dash errors. Took a look at it and realised it had LED rear lights so I couldn't do anything as there is no bulb to change. I expected to have to pay about £100 for a used light cluster, but upon further inspection I saw that the LED driver board on each light was removable and given that it's uncommon for an LED itself to die I thought I'd try swapping left and right driver boards around. The light then worked which proved it was the board at fault and a replacement pair was only about £12 so I ordered those.
I then discovered that there's actually 4 tail lights - 1 on each side of the car and 2 in the boot lid - and 3 of the 4 weren't working which is crazy. I did some further research and found a forum post with someone saying to just reflow the solder on the R750 resistor:
I dug the soldering iron out, took the old solder off and replaced it with some fresh solder and amazingly the light worked again. Repeated it for the other 2 boards and did the same on the working board for good measure and now I have all 4 lights working again. Was quite chuffed for the £100 fix to go down to £12 but fixing all lights for free was even better.
I (reluctantly) dropped the missus off at East Midlands at 4am Sunday morning.....it's only a 5 minute drive so ffs can't she just get a taxi and let me sleep......anyway.
Anyway I just realised I didn't pay the £5 charge, so it's going to have cost £100.
Obviously the system is designed to generate penalty charges. Thieving ****ing scum.
Redline is 8200rpm, I tend to shift at up to 6500 though as that keeps in-line with the expanded torque band from the remap (19Nm more torque from 5500rpm and 20HP more from 6500-8200) and the resonance where the ITBs and induction noise are at the best sounding burble zone. After 6500rpm it's mostly exhaust you hear and a higher resonance induction which sounds good but not as intoxicating as in the lower range.
E: Basically 6000-6500 is the sweet spot for sound, speed and gearing on such a road.
