- 19 Oct 2007
- Delete *.*
You know this is the one you really want
We've got one of the Makita ones that uses 2 batteries, around this time of year they seem to do an offer where if you buy the mower with a set of batteries you can get a freebie via redemption - when we bought ours one of the options was a second pair of 5amp batteries.I've got a few Makita 18v LXT tools, including two 5a batteries. So I'm thinking about going for one of their range.
The batteries aren't cheap though, so if I need more than 2 to cover the front and back lawns, then it becomes pretty pricey.
Very tempted by this, did you get it?I'm looking to get the EGO Power+ LM1903E-SP 56V Poly Deck Variable Speed Cordless Lawn Mower (with 5.0Ah Battery & Rapid Charger).
Yes I did.Very tempted by this, did you get it?
I have a Bosch Rotak 36V one. Had it about 4 or 5 years now. I'll never go back to corded or petrol.
This.Honda Izy
Mine is about 15 years old and still as good as new, serviced twice, and blade sharpened twice.Honda Izy
That looks similar to mine. It's a 43cm one. I think it was 430 model number, not made anymore. Battery still going strong. I could do with giving the blade a sharpen, or putting a new one in.Am still using this one with the same batteries that came with it
But it getting on it last legs now due to my own fault as i ran it over a large piece of metal in the lawn i didn't see last year which snapped the rear main motor/blade mount which is part of the plastic chassis
No problem in recommending it.
This is the one I've just bought. There are a few reviews on YouTube, one where the guy had only had it for a short while and initially raved about it but then in later videos he said it's utterly rubbish in wet conditions but I've seen others where someone is actually mowing in the tipping rain and he says it's decent.EGO LM1903E-SP 56v is the one I have
No idea how long delivery will take, hopefully not too long.
