Oculus Quest detects USB3.2 as USB2
15 Nov 2003
Marlow
Suppose no real surprise, but I noticed on my new build that if I plug my old Oculus Quest into the front USB slots, the Oculus software reports it's connected via USB2. Whereas if I connect it to the rear USB3 slots, it happily reports it's connected via USB3.
The front USB3 slots are 3.2 slots and I guess the Oculus is simply confused, so reports USB2.
Quest 1? Isn't it no longer supported now? As long as some of your USB ports are recognised by it I guess you're ok.
depends on the header the usb ports are conencted to as well dont forget. its not alway obvious what speeds they are. your sure the front is 3.2?
Yes.
I even downloaded/used USB TreeViewer to actively watch the Quest connecting to different USB headers on my system. I think it just doesn't recognise a 3.2 socket so reports it's USB2.
Well, the Meta PC app is working. The Quest is working. All my downloaded games on the Quest are working. Steam VR is working. ;)
Are your rears only USB3 (Mobo I/O panel?)
Presumably if rears are all USB3 it probably doesn't have the header to support 3.2? What motherboard are you using?
Assuming there's no actual damage to the Front USB ports i.e. other USB3 devices show up correctly
Could be the added length of the case's USB cable that causes connections to be marginal - I've had USB3 sticks not recognised at USB3 speeds with older/cheaper cases, but work fine in rear motherboard ports.
Can sometimes be resolved with PCI-E USB cards that have the appropriate header, and connect the front panel ports to that (as different chipset / dedicated power can make a difference)
Oculus using the same cable into three different USB slots. Front mounted wired into a special dedicate USB 3.2 Gen header on the MB . Rear IO panel one. And even a USB hub plugged into the rear IO panel.
Oculus software reports USB 3 for the rear one, USB hub, but USB 2 for the front panel.
USB Tree Viewer reports the front USB stop as USB3.2 when Oculus plugged into it. All the others are lower USB versions.
But do the front USB ports actually operate at USB 3.2 with anything else e.g. A flash drive?
Regardless of what USB Tree Viewer reports, if they never work with any other devices then it's either a physical port issue or the front panel cable isn't sufficiently high quality / isn't receiving enough power that devices fall back to lower speeds
Looking at the specs of your case, the front USB only supports USB 3.0.
So it's the case rather than your MB.
Why the quest detects it as USB 2 I have no idea
Here's the Quest plugged into my front USB3 sockets, a rear MB USB3 socket, and even a USB3 hub off a rear MB USB socket.
Note: The socket the Quest reports USB2 on is a USB 3.2 header/socket.
ps: Wonder why green and yellow?
Front USB socket
Note: There is also a USB 3 hard drive enclosure plugged into that front USB socket too for testing ("Mass storage device H").
The Quest reports USB 2.
Rear USB socket
The Quest reports USB3.
Hub in Rear USB Socket
@NeilF It's possible it's yet another meta borkdate. Multiple users are reporting USB-3.2/2 issues after the V76 update.
Aha! Thought it seemed to be the Quest having a spaz. Thanks!
I read that thread and seems to imply using a USBC header on the PC might fix it, and I have a USBC on the pc's front USB mount, but I can't be faffed with that.
The latest V76/77 borkdates are also rendering link/airlink inoperable.
My wired link is working.
Airlink? Is that a wifi link rather than a cable? Assume that's not supported by Quest?
Note: I had used the VR Desktop Stream app to wirelessly connect the Quest to my PC, BUT, when I implemented a mesh network it stopped it from working unfortunately. If I revereted back to just my standard router all was OK. Mesh, fail.
Yeah, I don't think meta implemented airlink for the Quest, which is probably why VD streamer was created.
Airlink is supported on all Quest devices, including Quest 1, though no doubt there will be issues on Quest 1 as it's no longer officially supported.
Just the fact that the last firmware for Quest was V51 and the PC app is at V76/V77 there's probably little hope of them talking to each other.
