- 4 Feb 2011
Just bought the above GPU
in another thread @loonyk spec'd out his costs for his own custom loop with a MSI Ventus.
Is there anything I'm missing here that I need? from that list originally provided, or do I need some other parts.
Also not everything is in stock at the moment, so if there are other in stock options they'd be appreciated
My Case is a Phanteks NV7 and it's the first time I'd be doing a custom loop.
Looking to what I need asap after some help.
Thank you.
Rich (BB code):
My basket at OcUK:
- 1 x Corsair Hydro X Series XD5 RGB White Reservoir / Pump Combo - 330ml (CX-9040007-WW) (SKU: WC-02T-CS) = £149.99
- 16 x Barrow 90 Degree Rotary Fitting - Black (SKU: WC-07Q-BA) = £3.95
- 2 x Barrow 30mm Male to Female Extension Adapter - Black (SKU: WC-05X-BA) = £3.94
- 2 x EK Water Blocks EK-Quantum Torque Plug w/Badge - Nickel (SKU: WC-A3B-EK) = £4.49
- 1 x Barrow Ball Valve (10mm) G1/4" Release Valve - Silver (SKU: WC-081-BA) = £11.99
- 2 x EK Water Blocks EK-Quantum Torque 14mm Rotary Male/Male Extender - Nickel (SKU: WC-A48-EK) = £4.99
- 1 x XSPC PSU Bridging Connector (24 Pin) (SKU: WC-021-OK) = £1.99
- 2 x Barrow Dabel-28b 360mm Triple Fan Radiator with 28mm Depth - Black (SKU: WC-005-BA) = £44.99
- 8 x Barrow 45 Degree Rotary Fitting - White (SKU: WC-07F-BA) = £3.95
- 18 x Barrow Soft Tube 16/10mm Compression Fitting - Black (SKU: WC-0C6-BA) = £4.99
- 5 x Barrow 16/10mm Soft Tubing - Clear - 1m (SKU: WC-09D-BA) = £4.99
- 1 x Alphacool Core 1 CPU Water Block - Silver (SKU: WC-0DF-AC) = £99.95
- 3 x XSPC G1/4" Stop Plug - (Black Chrome) V2 (SKU: WC-40F-XS) = £1.49
- 1 x Arctic P12 PWM PST Black Fan Five Pack - 120mm (SKU: FG-05J-AR) = £26.99
- 1 x Arctic P12 PWM PST Black Fan - 120mm (SKU: FG-04H-AR) = £5.95
- 1 x XSPC Heavy Duty Hose Cutter (0-25mm) (SKU: WC-341-XS) = £6.95
- 2 x Mayhems - PC Coolant - X1 Premix - Eco Friendly Series, 1 Litre, Clear (SKU: WC-035-MH) = £14.99
- 1 x Barrow Leak Tester (SKU: WC-0C8-BA) = £26.98
- 2 x EK Water Blocks EK-Loop Soft Tube Cutter (SKU: WC-9WW-EK) = £3.95
Total: £699.53 (includes delivery: £0.00)
GRA-GIG-04118
£3,200
(incl. VAT)
£5
(incl. VAT)
SAVE 36%
£70
(incl. VAT)
£45
(incl. VAT)
£15
(incl. VAT)
