I foolishly bought 100m of cat 5e F/UTP as well. Which I would return but I cut off a bit to have a go at terminating it.Yes that’s fine. It will be a little less flexible but it’s all good.
You’ll be surprised how far a 100m doesn’t go once you get into it![]()
Yeah I just sucked it up and ordered this for internal:The external stuff (Euroclass FCa) usually gives off nastier fumes when it burns compared to things designed to go indoors, and doesn't self-extinguish. It's a trade-off for the UV protection that the exterior grade cable has. You'd probably not be allowed to use it indoors commercially, in your own house it should be fine, just don't set fire to it if you can avoid that.
It's not a fire risk it's just more dangerous when it eventually does burn, and a good reminder to make sure your smoke alarms are all in good working order and you have enough of them.
Too late now. Got a box of UTP 300m sat next to me. I live 10 mins away from cable monkey.In all honesty I wouldn’t have worried about it. I’ve got CAT6A rammed into regular CAT6 keystones with zero attempt to make off any of the shielding.
Does it meet speciation? Not a chance in a month of Sundays.
Does it work? Yup and that’s all that matters.
I had what I had, I just used it rather than worrying about what is ‘correct’.
Where is the soffit?Anyone fitted the new U6 turrent on a softfit? Been looking at them, but I believe size wise they're a fair bit more chunky than the G5 turret ultra. Add the new in box ultra I have is black and now wish I'd got a white unit.
After further digging and finding this on an Intel forum, It would appear that my hunch of auto optimisation is causing the issues and why it would work fine for ages and then suddenly not.I think I figured out my work laptop issue this evening. By default, the 5Ghz band is set at 80Mhz channel width. It was giving me big issues tonight. Switched it to 160Mhz and straight on. Not blipped since.
I'm quite tempted with the G6 Turrets too. An upgrade later in the year I think.Am I right in thinking the G6 turret has the same mounting screw holes as the G5 Ultra, it's just a bigger camera.
First thing anyone should turn off, it causes so many issues.auto optimisation
Thanks, I'll get this turned off today. Is there anything else I should be looking to remove for a home setup?First thing anyone should turn off, it causes so many issues.
Yes I like the G5 Ultra that I have covering my driveway and car parked on the road. I'll swap that for the G6 and move the G5 to the black garden and use it to better control the LED Floodlight I have.I'm quite tempted with the G6 Turrets too. An upgrade later in the year I think.
