*** Official Ubiquiti Discussion Thread ***
I just order my UCG-Fibre.
Before I order a new WiFi access points I better check if people seen any problems in mixing WiFi 7 with WiFi 6 access points I could keep the whole system on WiFi 6 and just buy a U6 in wall for the garage.
The plan was I was to replace the U6 Pro in the loft with a U7 Pro or maybe U7 Pro Max, buying U7 in wall access point if needed and moving the old U6 Pro to the garage for my solar/GivEnergy battery system/EV charger that requires WiFi that running on a very old AC Pro.
I do have devices that run on 6E and WiFi 7 a mixture of Android Pixel 9 phones, tablets, Apple iPads, Macbooks Pro which would benefit going to WiFi 7 setup.
Thanks
Simon
Be careful with the GivEnergy inverter. My Gen 3 5kW hybrid inverter only supports WPA2 so I had to disable the 6GHz band in order to select WPA2-only.
I’m now using a powerline adapter instead.
Turn 2.4GHz off on your main SSID that things like your laptop are connected to. Make a 2.4GHz-only IoT SSID and put the old things on that.
You really have no need for a network that is only going to have modern devices on it having the 2.4GHz band still enabled.
Just pointing it out because it’s the only device that couldn’t connect when the router was set to WPA2/WPA3.
Yes I found that I had to lock the GivEnergy WiFi dongles to the garage Access Point as it kept moving to different AP in the house and losing signal. I will also look into creating a separate 2.4Ghz network for IoT devices.
I may leave the U6 Pro in the loft, add a U6 in Wall with 4 Data-out: GbE RJ45 ports to the garage as it these units handles better Ambient Operating Temperature and use U7 Pro Walls on desk stands in parts of the house for devices that require WiFi 7
No worries. I'll keep searching. For the cost of an ultra, I be as well buy new to be fair.
It took will get fitted along with the outdoor AP when I get round to it. Part of the Unifi experience I'm finding.
Has anyone grabbed a U7-LR yet?
I was just about to hit buy on a U7 Lite when this popped up on the store unannounced (or at least I hadn't seen it before so I assume it's new). I was planning on sticking it on the wall above the stairs - we have a U-shaped staircase so I'm thinking that positioning will allow it to blast it's Wi-Fi goodness horizontally across both floors quite effectively rather than have it radiating downwards through a floor. The U7-UDR is at the opposite end of the house.
Any reason to not get this over a U7 Lite for the extra £55? 3x3 on the 5Ghz seems a slightly strange choice. I'd have loved a Wi-fi 7 AP that dropped the 6Ghz in favour of 4x4 on the 5Ghz, at a sensible price. Or should I stop being a tight-wad and just get a U7 Pro XGS because it'll be worth the extra (extortionate) cost?
G6 Turret seems great so far. Much better mounting bracket and system, a lot easier to get it pointing where you want it. Exact same holes as the G5 Ultra.
License plate recognition has been spot on so far.
See what night time quality is like.
Do the cameras come with a mounting junction box similar to Hikvision or is that an added extra?
If I had the WAN port of a Unifi gateway connected to the LAN port of an upstream Unifi gateway (providing internet to tenants scenario), would I need to do anything special with the firewall rules to prevent the tenants kit attempting to be adopted on the primary controller or vice versa? Or is the fact that it's only connected to other Unifi stuff on a WAN interface enough to stop it trying?
Tenants kit as in UniFi kit? Yes, I think you'd need to block their adoption/stun ports from reaching the upstream gateway, otherwise they might show up.
