Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
11 - warm
12 - k11 r2r
I avoided words like Midriange, Bass response, vocals on purpose, coz that won't be fair lol but K11 r2r is genius lol
11 - warm
12 - k11 r2r
AgreedI kind of agree that simpler is better, my marantz amp has spotify integration and bluetooth support etc. I don't use spotify anymore and now the bluetooth on it has gone funny and I cant get it to pair anymore. Its the same with smart tv's, i just want a dumb tv that i can plug what i want into without its slow "smart" interface getting in the way of my life.
This is why pure analogue only gear is sometimes better, less to go wrong, plus if it's high quality it will still have value in 10-20+ years.
So my main HiFi gear I use Wiim Pro for streaming, think I paid £110 in a sale. Of course I connect it digitally into a external DAC, then an pure analogue amp. If in say 5 years the Wiim Pro dies or it's not supported it does not really matter as it's external to my better gear, so the Wiim it's kind of disposable in that sense.
I was looking at the Yamaha R-N2000a that's a higher end Yamaha integrated with all the streaming built in, it's an amazing versatile amp, but if something on the digital side fails or not supported, you left with an expensive amp that's at best out of date, but pure analogue gear will never go out of date.
Same story with my studio monitors, pure analogue with no digital domain, and not reliant on any software updates.
The older I get, the more I agree with this.
I have for example removed all my Amazon Echos...they worked and then they don't....I just can't be bothered to fix them. I don't need voice command to turn on my lights. A light switch is tried and tested technology. It's fine.
What I am resisting real hard a lot of things get an "app", you can now get an app for a toaster, you can get a screen and app for your fridge, you can get an app for your coffee scales, I even have an app for my bathroom scales too!
Part of my concern is when these companies pull support for the app, will the app always be available to download? At minimum they won't support them forever, especially for a small company. Even big companies like Fuji will pull support on old apps and release a new one.
Not always. I've had more imbalance issues with pure analogue amps than solid state. For example all NAD analogue amps have low volume imbalance, you need the dial at a certain level to get perfect stereo channel balance, otherwise one channel is louder than the other if too low. Digital volume pots resolved that but introduced noise into the circuit on that era of amp. Rotel was no better, I had the RA-02 with issues. One of my other NAD's power transformer failed too once.This is why pure analogue only gear is sometimes better, less to go wrong, plus if it's high quality it will still have value in 10-20+ years.
I'm going off on a slight tangent here...
For anyone into higher-end stereo audio, your goal is to buy gear that you never have to replace, then you spend you time on the music and forget about the gear.
The manufactures want you to continually purchase gear, the YouTube channels and review sites they all push it. I'm not against new gear as it's getting very good, especially the advancements in class D amps. But by integrating the digital side, then the apps, their encouraging you to keep changing gear.
At alternative approach is to buy pre-owned gear (it's taken it's devaluation hit) that's been higher end and it's not reliant on apps or updates, then like myself you have an almost disposable Wiim Pro for the streaming side.
Oh yeah its size means it's also a personal radiator as it runs rather warm
Just an observation but Liking the k11 r2r runs counter to this though. It has objectively less detail than a sigma delta dac.I think you misunderstand. I'm in it for the music, I want to be able to hear details in music that previous were not clear because the creators of that music intended them to be heard else they would not have used those instruments or mastered the track that way.
That is what the musical journey is all about, if I upgrade my speakers years later to discover hidden details in my fav music then that's a total win.
You want true authentic music, then you need to find the equipment that brings out the truth in that music. You can also fully enjoy the music in the process, like I did and continue to do. It doesn't have to be one or the other, it can be both, and I am proof of that. You just have to not be closed minded.
I don't think it does, I've been A/B testing both back to back and the details are all there between them both, it's the presentation of that sound which is different between them, and then moreso once you enable the EQ features on the X9 and it overtakes cheaper DACs by a good margin. The K11 R2R in OS mode on my headphones and speakers specifically sounds the most detailed due to the internal resampling that takes place in OS mode. NOS mode is the factory default which I guess is what most people will stick with under the presumption that it's the "pure" option to use.
