- 11 Oct 2005
- Doncaster
System
Windows 11 Pro (latest build)
MSI MAG X870E Tomahawk (latest BIOS)
AMD 9950X3D
64GB Kingston Fury Beast DDR5 PC5-44800C30
Kingston Fury Renegade PCIe 4 500GB
Antec HCG 1000 Pro
Thermalright Peerless Assassin 120 SE
I have been having this problem with this new PC with Windows 10 so did a fresh install of Windows 11 and the issue is still there. The problem being is high CPU usage and Temps when opening any sites that use java (I know simple answer don’t use any sites that uses java) this is happening when using any browser it is also happening with a couple of media players like MPC-BE & VLC, CPU & Temps not as high as when java but it is still there. Not once did I have this problem on my last system which was an old AMD 1700x.
This has got to be a Windows issue because last night I installed Fedora KDE plasma and not once did I see any high CPU usage or high Temps going on the same sites and using any media player. I could stay on Fedora but I use Staxrip quite a lot and it’s not supported on linux.
Anyone else seeing these issues within Windows on a similar system.
Much appreciated for any help with this one.
AMD 9950X3D
Antec HCG 1000 Pro
