- 4 Dec 2008
AC Freezer II PRO even better, quieter pumpArtic freezer 3 best one I've ever owned.
i didnt even know that was a think. looks like the III with better fansAC Freezer II PRO even better, quieter pump
Out of interest, what's wrong with NZXT products? I have the kraken 360 AIO and it's pretty good.I’m using the NZXT Kraken Elite 360 and I’ve used them in all previous builds without any issues. I wouldn’t touch any other NZXT product but the AIO is decent.
Will have a watch
The video someone else posted explains the main issue.Out of interest, what's wrong with NZXT products? I have the kraken 360 AIO and it's pretty good.
I have used AF III on my Intel build for some time. Good cooler but do not like have to remove the socket retention bracket to fit their own, for my socket 1700 Intel build.
Corsair Nautilus is relatively new and seems to be quite well received, that I have noted so far.
Decent price and performance.
Yes, I have the Corsair Nautilus and is a good cooler.
Mine has arrived. There is no manual, but at least an online guide..!
yeah, fairly easy to put together though, but like you said if assistance is needed there is stuff online!
Indeed, not a problem really. But kinda disappointed as the motherboard I just bought had the flimsiest of sheets with it, in several languages. Not much about the front panel, where you plug the power switch, reset switch etc.
Do you use any software to control the pump etc and the lighting..?
Thanks
Is this still for sale? I was under the impression the III/III Pro had taken it's place?AC Freezer II PRO even better, quieter pump
As far as I know PRO is for saleIs this still for sale? I was under the impression the III/III Pro had taken it's place?
yeah, it is a bit annoying for mabye someones first time with an AIO.
I dont mate, all my fan settings I do in the BIOS, and I left the pump and fans on stock settings. I dont have any RGB on mine as I bought the "blacked out" version of the AIO.
You can use iCue software etc.. but I have a mate who has had a few PC issues he reckons might be related to the software. (Not 100% sure so take it with a pinch of salt).
