- 9 Dec 2009
- Bristol
Rear discs weren't too special, so I replaced them for grooved and dimpled, which now match the fronts.
Also replaced the caliper slider boots, and cleaned and greased the slide pins.
After bleeding the rear calipers I bled the fronts, then bled the clutch. I was going to do an oil change while I was under there, but realised that while I did buy 5 litres of magnatec in the winter in a sale, I'd not bought an oil filter!
Also replaced the ageing wheel centre caps with some cheap eBay jobs, which fitted well.
She just needs an oil change and a good clean and polish, then she'll be ready for our road trip to Italy in four weeks.
