Literally the most base spec car I've seen in my lifeAny advice? Like the look of this but considering it or a cmax…is this likely to cost a good wedge more for service/repair?
Auto Trader UK - New and Used Cars For Sale
Find your next car with Auto Trader UK, the official #1 site to buy and sell new and used cars. Over 400,000 cars online. Simple, easy, quick!www.autotrader.co.uk
Great, thanks.Literally the most base spec car I've seen in my life
How big is the interior of the 2GT compared to the cmax?
Yes, 7 seats is the big thing really and all of the Ford’s are either eco boosts or dieselIt’s got all the mod cons, navigation, cruise control, 1 owner from new, its hardly the worst deal of the century.
I’m not particularly fond of these but if you like it, the service stamps are there, shop about a bit, test drive and go for it. I’m guessing these will be better quipped than the Ford.
Is that to service the chain or replace? Do they usually go at that mileage?Get a test drive booked and if you’re happy then go for it.
Sounds like it would fit your requirements, it’s reasonable mileage for the age and all the equipment you’d probably need.
Make sure to check the chain schedules on these engines.
There isn't a scheduled replacement for the timing chain on any of the BMW modular engines B38/B48 (or even the B58) - it's a "lifetime" component.Make sure to check the chain schedules on these engines.
Super sports are very definitely a summer tyre, by all accounts poor in low temps so if you’re not swapping wheels/tyres for winter and it’ll be used then too I’d avoid them. The 4s isn’t great at low temps either AFAIK. CSC7 I’d probably go for.Goodyear F1 Supersports, CSC7, PS4S or PZero * ? F1SS is almost £100 less than the CSC7![]()
The CSC7 is still the newest Conti sports tyre so still has a premium.Yeah my head says CSC7, but I wasn't expected the F1SS to be that much cheaper... Still have plenty of tread on the PSS* but just fed up of the lack of grip.
I have a set of winters, but would still rather have the best possible tyres for the rest of the year, which is what I normally do. Was just surprised at how expensive the CSC7 are![]()
Not available in 265/35R19The CSC7 is still the newest Conti sports tyre so still has a premium.
Thought about Pilot Sport 5’s? I have them on my 428i. 20k miles and still loads of tread.
The 7's are apparently much better in that regard as it was a known weakness in the previous model.Not available in 265/35R19
Looking again, CSC7 are halfway between the F1SS and PS4S so not so bad actually. Is the wear rate still as poor as Contis in years gone by?
You won't regret CSC7, they are in a different league to the PSS.Yeah my head says CSC7, but I wasn't expected the F1SS to be that much cheaper... Still have plenty of tread on the PSS* but just fed up of the lack of grip.
