DeskPi rackmate T1?Ideally not, I change my mind as often as I change my underwear when it comes to hardware, so don't want anything like that. I'm also moving house in the next 12 months.
DeskPi rackmate T1?
Yes, The difference is height, I believe the T0 is 4U and the T1 is 8U.Interestingly, looks like someone has asked the exact same question on /r/homelab, so hoping there are also some replies there too. But for the T0, assuming the main difference is height.
No, It's generally quicker for delivery too.Any difference between ordering from the EU Store rather than the UK?
EU has a few bits in stock that the UK one doesn't? (Gateway Max No Storage and the POE)
Just the plug issue i guess?No, It's generally quicker for delivery too.
They generally bundle in a UK plug also.Just the plug issue i guess?
From my general reading online, I believe one is made for US and the other for rest of the world.Is there no difference between the radios in the WiFi items EU Vs UK like there is with the US?
The CGU; it probably is one of the best devices for a 1Gb or below internet connections. The in vogue device is the CGF device, which is a very good device for the money.So to replace an AX86s and a RP-AX58 that's upstairs via wired backhaul.
Cloud Gateway Ultra
U6-Pro
POE Adapter
I might be able to get away with not needing another access point upstairs, depends on how well the U6 Pro performs I guess. I should able to move the AP so it's a bit more central in the house downstairs.
Does that seem/sound reasonable?
CGF is a bit overkill for what I need really. 900/450 connection, so the Ultra should fit the needs.The CGU; it probably is one of the best devices for a 1Gb or below internet connections. The in vogue device is the CGF device, which is a very good device for the money.
I'm looking at a similar setup myself and I was supposed to get the U6 Pro from a member this week but the Post OFfice has lost the parcel so I need to buy retail.So to replace an AX86s and a RP-AX58 that's upstairs via wired backhaul.
Cloud Gateway Ultra
U6-Pro
POE Adapter
Yeah i'm still looking into it, as to what's best. Majority recommend the Pro over the LR.I'm looking at a similar setup myself and I was supposed to get the U6 Pro from a member this week but the Post OFfice has lost the parcel so I need to buy retail.
Just so you are aware, the U6-LR has a better 4+4 MIMO setup (4 x 5ghz, 4 x 2.4ghz) setup that would give you a wider range than the 4 x 5ghz and 2 x 2.4ghz MIMO setup of the pro.
Another thing, you should mention competitors (you've mentioned one in your following post) and try not to use massive organisations like them, try use smaller companies that actually pay their corp tax and don't work their employees to the bone. Your choice of course.
Just another thing to note here with the U6-LR is WiFi 6 for 5 GHz. WiFi 4 for 2.4 GHz.I'm looking at a similar setup myself and I was supposed to get the U6 Pro from a member this week but the Post OFfice has lost the parcel so I need to buy retail.
Tbh, that's way over what I was hoping to spend.What about the following:
UCG-Fiber
U7-Pro-XG
Those come in around ~£465 + Del (UK Store Prices)
Then you have no PPPoE worries, and you also have the option to add an NVMe for Protect at a later date. That's a much more robust solution, in my opinion.
