- 26 Aug 2004
- South Wales
A few times now I've had delays when accessing my SSD, I tried to open a folder earlier and it took about 10 seconds to access it.
I checked Event Viewer and found this
Then I got a popup from Windows about repair..
I ran a scan with hdsentinel
Anyone know why this is happening? I'm using USB A to USB C cable at the minute, I'm pretty sure it did this when I used the C to C cable as well.
I contacted Samsung support but I'm not sure what they will suggest.
It doesn't seem like the drive is bad but.. who knows?
I did transfer files to it from a WD MyPassport not long ago because it developed a bad block, and that was connected at the same time I got these errors, but the Event Viewer is pointing to the T9 so it can't be that.
Oh I also had this one before as well:
