- 19 Jan 2007
- Up a Tree
One seal on my Argos Switch 2 pre-order was intact but the bottom seal was only half on.
Query regarding HDR setup on OLED. when first docked, it wants to perform the obligatory make the left logo visible exercise. On my TV, I kinda had to go hard left to make the right logo disappear with the left logo barely visible. What are others experiences?
Same. I made the right image disappear but the right one was barely visible as well. Seems ok so far but if there is a better setting I’ll try that.
Essentially HDR is bad in portable mode (a limitation of the screen) and pretty good in docked mode.
I didn't do anything scientific or actually time mine... but I'd been playing it in tabletop mode with my 5 year old son before he went to bed.2hr 20mins from 100% to 0% playing Mario kart
In the Virtual Game Cards menu I only get a 14-day warning when selecting 'Lend to a Family Group Member', but no 14-day warning if I select 'Load to another console'. I only had to do the physical, get the consoles close between the Lite and 2019 Switch one-time.
It might be easier in the long run to have them build up their own account/library. In that if they ever get another Switch then they'll have this malarkey to deal with too.
Ah OK this is the online license setting you were on about.
I think for me I'm going to set re-org my Switches on Sunday so the 2019 Switch is the main & the Switch 2 is the secondary, or vice-versa. And then the Lite and OLED will just have to play physical games - which to be fair is most of my Switch 1 games. I was going to go all-digital on Switch 2 but this does put me off a bit.
Hey guys the Switch 2 is arriving from Amazon today, quick question on system transfer.
Do all the games that I have on my Switch oled get transferred over to the Switch 2 automatically.
Reason for asking is that I have got a 512gb card in the oled switch and won't have enough space in the Switch 2 to copy them over even with a new 256gb microsd express card.
Not worried about downloading them again as all my saves are backed up in the cloud apart from Animal Crossing.
Cheers All
Not in my case. It only transfered system settings and saves as far as I could tell.Hey guys the Switch 2 is arriving from Amazon today, quick question on system transfer.
Cheers All
Ok thanks that answers my question.I needed to download them all again.
Cheers All
Cheers All
It's pretty annoying that Nintendo/developers cannot seem to get HDR right when consoles are used under certain conditions (docked in the case of the Switch).
It only transfers saves and settings. Games and apps will need redownloading. For me since I had <256GB install on my NS1 it just redownloaded everything I had installed there onto my NS2. It will probably ask you what you don't want download or you'll have to go round to each game/app and manually cancel after you reach the final step in the transfer process.Do all the games that I have on my Switch oled get transferred over to the Switch 2 automatically.
I pick up this one and will be installing it today when the switch 2 arrives.Managed to mess up my screen protector install, can anyone recommend one they are using? I was looking at the Spigen with the template but it's £25!
