- 21 Dec 2019
- Planet Thanet
It's worth checking the riser worksI enabled XMP and seemed to work okay.
One thing that I should have done (realised afterwards) is to test that the pcie riser cable worked with the motherboard. I did not see a pciex16 gen setting in the bios but will need to do this before I put the motherboard in the case.
I shall put some photos up of general case layout ideas and get some opinions before I commit.
There may be bifurcation settings in the bios
Even if it ran at x8 you wouldn't notice the difference
It's unlikely to be x8 if not using a lot of m2/sata drives
Or anything else that needs pcie lanes
