Paid the bill :S
Least these won't be due for another 7 years or so lol.
Be interested to find out if that gun or connectors leak in use or at rest.
No meaningful leaks so far, I did a quick pressure test in the porch over a bucket. Couldn't confirm if it's 100% water tight, I suspect it is once up to pressure but not before.
Annoyingly I've got a weep at the jubilee clip onto the tap, I suspect that's unavoidable with this stiff hose.
No meaningful leaks so far, I did a quick pressure test in the porch over a bucket. Could confirm of it's 100% water tight, I suspect it is once up to pressure but not before.
I must be unlucky as I've encountered more that leak or seep over the years than those that have remained dry.
Bought a no name recently after my last Hozelock gun decided to just give up and spray everywhere other than from where it should.
That's usual for me with Hozelock connection and hose leaking at the tap.
TBF I've only used it for an hour from new, there's still time for it to start leaking :P
nice to see their home - when doe the live streaming start
If you’re using a pressure washer, remove the aqua stop
what do you think is wrong with aquastop ? they don't narrow the bore any more than the typical hoze bore (until I get a 3/4)
and they are ideal for quick plug&play for karcher car washing
It's to do with letting the water flow both ways. Preventing backflow can damage some pressure washers as you stop spraying, the pressure needs to release somewhere.
