and reduces idle power draw by 60%
I bet it does :s pretty much the difference in idle power draw between Windows 7 or Linux vs Windows 10/11 on my mini PCs.
Still not a fan of it at all.Maybe maybe we will actually get a useful Start Menu.
You should not need to reinstall anything, just uninstall Z790 specific drivers and that's it, Windows 11 handles everything else basically perfectly.
I had to disable mine from the bios to stop prompting me to install it every time I turn the PC on. I do not want it and I have no use for it at all.Gigabyte seriously needs to redevelop their control centre and remove all the telemetry and AI **** - the software is a disgusting mess which can degrade performance in several games. Fortunately there is no actual need to run it - if you need the RGB control there are better applications.
The awful GB software, turn it off, uninstall software![]()
My Gigabyte X870 Eagle board came with the manual, you can also download them from the Gigabyte site.
I have done this a few times when I cba to get up to find the manual
