Flightradar is showing activity there, so it would appear it is indeed reopen
Yep, a flight to Delhi has just taken off flying right over the crash site
I've only seen a short video so I say it's difficult to say what has gone wrong. Also, I'm not a 787 pilot.
But it is possible to take-off in ground effect and and then lose that lift once airborne but I honestly can't tell if that happened here. Regarding intersection take-offs - they're completely normal provided the correct performance calculations have been done.
However misidentifying the correct intersections has happened in the past and led to accidents - I know of one case where they overran the runway, taking out the runway lights before getting the aircraft airborne (with quite significant damage).
But as a modern aircraft - the 787 should have an on board warning system which will tell you if you are using the incorrect intersection (or if the runway length is insufficient - I've never used it though so I don't know the exact details of how it works). I think it may be an optional extra however - Boeings are like BMW's where you have to specify pretty much every feature you want when purchasing (for an additional cost, of course).
I suspect the FBW system on the 787 will not allow you so stall the aircraft (it will allow you to pull back to just below the stall and keep you there if you continue to pull back). If you're too slow you are still going down.
To me that's what it looks like. How it got so slow - I don't know, incorrect flap selection or some kind of mechanical fault, I would guess.
The 787 should be a very safe aircraft.
Battery fires are pretty intense.How tragic.
I do find all the commentary from people frothing at the mouth to demonstrate their aviation knowledge, particularly cringe when these things happen. At the same time, it's kind of interesting.
I wonder how many crashes like this would have survivors if there was no fire from the fuel. I'm just saying in a hypothetical situation, say the plane ran on electric engine and fuel fire was completely out of the equation, how many would still perish just due to impact/debris/forces and deformation of the aircraft. I would assume still very high.
This is the 1st of its kind for the 787.They don't have the best record those planes.
Although I guess this might be human error?
Yes, but they don’t have the same pressure wave as a fuel vapour explosion. Jet fuel is basically kerosene these days which is less flammable and explodey than gasoline, but you’re still getting a blast wave that venting/burning battery packs won’t produce until they cook after burning for a while.Battery fires are pretty intense.
Christ that's grim, hope it's not too bad
Sadly India's H&S culture is virtually non existent and they're one of the most densely populated countries in the world so the aftermath is going to be proper nasty.
Gonna be interesting to see what the cause is, it'll be hard for Boeing to recover from this one I reckon, regardless of who's at fault people will be out for blood and they're on a pretty sketchy footing as it is.
But you are a pilot (If I remember from the other incident threads) so it’s valuable input to help my engineer brain think about it.
It would seem to be loss of thrust for some reason - if the RAT has deployed automatically which has been mentioned then I would expect that due to sudden loss of electrical power (or hydraulic, depending on the 787 architecture)
I don’t think there was enough time for the pilot’s to have done it, or really done ANYTHING in terms of procedures although they did get a mayday call out. Gear is still down too which implies a distraction at the moment of takeoff, and it should be fine on a single engine at that point I think?
Would this be poor maintenance issue I mean as somebody pointed out India dosnt have great health and safety.
Mad that any airport is so close to human population only takes something like this and loads of people on the ground can end up killed to.
From the video in the ops post the flaps do look to be up and not correctly configured for take off. Also you can see the plane sink and that is the behaviour expected and has been seen many times when planes take off configured incorrectly for take off. Many such accidents have happened and ended up in this manner and the plane reached a maximum altitude of 620-625 feet according to some flight tracking sites.The flaps were fully retracted and the landing gear was down, at this point in the flight the opposite should have been the case....
so far. But lets wait for more footage and seems the tail section is in good condition at the crash site so recovery of the black boxes shouldn't be an issue and then they can check the FDR and CVR (flight data recorder and cockpit voice recorder) to confirm the take off configuration and what alarms can be heard were going off on the CVR and what was being said by the pilots, seems they did send a mayday too, but at what point of the take off.
