It would have to be a pretty epic software fault to turn off both engines.If the fault caused loss of electrical power it does.
It won't have been overweight, it wouldnt have had a full fuel load as it wasn't doing anywhere near its max range.Could it have been overweight, as presume 250 is max capacity and having seen Indians coming through airports with several huge suitcases each , or would it need lots more than say 1000 suitcases to make a difference.
No, not even close.Could it have been overweight, as presume 250 is max capacity and having seen Indians coming through airports with several huge suitcases each , or would it need lots more than say 1000 suitcases to make a difference.
It would have to be a pretty epic software fault turn off both engines.
Yeah it's a decent guess, just the way the plane slowly sinks - it looks like something totally stupid is going on with a fundamental control system.
Based on what we had with the MAX, it wouldn't surprise me if something similar(ish) is to blame, and it boils down to a rare bug, or other condition.
What happens when those systems fail, take over the aircraft and cause it to crash despite pilots doing everything they can i.e. MCAS on the 737 Max 8?I'm actually surprised how many crashes come down to pilot error when you would think that they would build systems that simply do not allow for such inputs to be allowed.
Well a software fault could quite literally do anything to anything. Any unexpected condition where the software has literally had a "fault" will mean it has broken free of any expected boundaries and you would expect the unexpected. Things are off limits then. It could be something super specific and rare, which caused such a crash (logical) that the internal system behaved strangely.
Just as one example, I remember the one where the pilot allowed his kid to fly the plane whilst it was on auto pilot seemingly not actually adjusting the course at all. The kids inputs were held for such a period in one direction, that the auto pilot disengaged and it pitched the plane to such a steep banked turn, that it went almost to 90 degrees. The G force caused one of the pilots to barely be able to get back into his seat for a while. This was beyond that which the aircraft was designed for. A stall followed, spin and eventual crash into the ground. Everyone died. Why would the system allow a turn to be made beyond system design? Why allow manual human control to be even able to perform such inputs?
The fact it’s taken 14 years to happen would suggest the opposite - it’s some innocuous line of code somewhere which combined with set of circumstances and is a trillion to one chance of happening.
The fact it happened at the change between ground and air mode is another red flag for software.
Silly question, but I take it that the plane computer knew the plane was about to fly directly to the UK and would prevent takeoff if the plane hadn't been refuelled sufficiently?
That's not what I asked.Yes, the aircraft will be preprogrammed with a destination. It then detects how much fuel is in the tanks and if it's not enough, it cuts power to both engines mid air to let the pilots know.
I was wondering if it was possible for the flight to have taken off on fumes from the flight to India, or would the plane computer prevent attempted takeoff.
14 years is irrelevant if the series of scenarios was there from the beginning it might just be now that it has happened.
Some checklist might have been missed, combined with something else and those chain of events caused the plane to crash. There are so many redundancies in planes now that a "computer bug" will not bring down a plane.
Aeroperu flight 603 crashed due to pilot error in some respects but the main culprit was all the static ports were taped over due to maintenance with silver tape which were hard to see as they were the same colour as the fuselage and were missed by the pilots on visual inspection before take off. The pilots had no reference to altitude whilst flying at night because altitude is calculated by the static pressure around them and airspeed is also calculated by the dynamic pressure and static pressure so that was wrong too as rate of climb would be too.
This tape solution was the known servicing method at the time and after this accident was changed.
Boeing 757 was introduced in 1983 and this accident which was waiting to happen. Happened in 1996. 13 years later.
I've read other pilots saying that the flaps weren't in the right position for take off
No conspiracy just in my opinion it's a strange way to act and a near impossible situation. Truly staggering.Whats the conspiracy this time? That he wasn't on the plane?
