- 5 Nov 2014
Thanks for the recommendations. The prime seems to be discounted at the.moment albeit you have to pre order. Oc has it for 450. Probably a bit much thatHere's a list of noise measured from a few 5060ti and most of them seem to be in stock with OCUK
Palit GeForce RTX 5060 Ti Infinity 3 16 GB Review
Priced at NVIDIA MSRP of $430, the Palit GeForce RTX 5060 Ti 16 GB Infinity 3 is a cost-effective choice if you're looking for a model that doesn't break the bank. Palit didn't compromise on the cooling solution, our review confirms: it runs cool and at quiet noise levels.www.techpowerup.com
I think the 3 fan cards fit in the Formd T1 but you should double check.
The Palit infinity 3 and Zotac Amp are louder but 30db is still not loud
It might be worth paying a bit over budget for the ASUS prime if you are really concerned about noise.
