£1k upgrade
thanks :off to find a cheap source of reclaimed clay tiles:
When you told your wife you'd buy her a gazebo, did you tell her how big it was going to be?
Bugger the motherboard is pre-order - I've got to get in before the Indian sandstone flooring is ordered....
I'd switch to the T500 2tb or the Renegade NvME, they're a similar class/quality of drive and will save you £30-40, the 9900X benefits from faster RAM (6000/c30 is the sweet spot for non X3D chips) and it'll open room in your budget to switch to the Corsair sticks recommended by myself and @tamzzy earlier.
Do you really need the feature set of that motherboard? You could knock £100 off there too depending and still get a very good motherboard.
I'd be looking at something like this unless you really need USB4 or whatever else the Tomahawk offers:
My basket at OcUK:
Total: £1,317.86 (includes delivery: £7.99)
Motherboard review (linked to VRM section with it running a 9950X):
My basket at OcUK:
Total: £1,317.86 (includes delivery: £7.99)​
Motherboard review (linked to VRM section with it running a 9950X):​
Fully disabling the PCIE2 if the m.2_4 is used is a no for me. I've accumulated several m.2s and will likely add more, so want to be able to use all the slots. I could use a PCIE for m.2 add, in, but current PCIE lanes are soooo stingy ;)
Fair enough! It's a bit of a pita at the moment dealing with the various trade offs on motherboards.
The RAM/NvME switch is still worthwhile however, you'll not notice the difference between the 990 and Renegade but you likely will with the RAM.
The 990/T500/Renegade are all high quality Gen 4 drives with DRAM and high TBW so rule of thumb is to just grab whichever is cheapest, there's a couple of others out there on par too.
I've got Crucial drives in a bunch of laptops and they've been great. I just have a default for Samsung because I worked for them for about a decade, never managed discounts on components though... :)
The working out which pcie lane is cut/closed by what is really really f-ing annoying :)
Looks good to me, as mentioned by @mickyflinn the Zotac does offer a longer warranty, although I'm not sure which of the two offers the best acoustics if that's a concern. If so, the "Asus Dual" models in the past are well regarded, but be wary of the Evo variants as they're cut down and quite poor by comparison.
I actually own a Zotac 4070 Twin Edge and its been a good experience, I rarely hear it under gaming loads but workloads may differ.
£450 (incl. VAT)
£350 (incl. VAT)
£310 (incl. VAT)
£290 (incl. VAT)
£155 (incl. VAT)
£132 (incl. VAT)
£420 (incl. VAT)
£400 (incl. VAT)
So before I accidentally buy an outdoor wood burner, and/or a Big Green Egg..Is this OK?
snip
Looks good, wrong RAM though, one sec.
You want this RAM specifically, it's EXPO and lower cas latency (aka quicker). EXPO is essentially AMD's version of XMP, so a set and go thing in the bios.
